If you have H&R/KYB-GR'2 setup,, need feedback.
Old Oct 31, 2003 | 12:09 PM
2k2MerlotSE's Avatar
JUVIN's ride
I've been searching around on this setup for tire wear and camber kits.
There are differences in opinion. Some say they need camber kits/bolts and others say no.
How are your tires wearing? Do you or did you install any type of camber adjustment kit/bolt?
How many miles on your current suspension setup?
I have a 99.
Thanks in advance.
Old Oct 31, 2003 | 12:14 PM
njmaxseltd's Avatar
The H&R drop does not require camber correction.
Have your alignment set and your tires will ware normally.
Old Oct 31, 2003 | 12:17 PM
JUVIN's ride
thanks for the reply. That's what I though. But after reading 7 pages of post I started to get confused because of the difference in opinon.
Old Oct 31, 2003 | 05:43 PM
chris j vurnis's Avatar
I would say the necessity of the camber bolts depends on how well matched from the factory the camber is between the left and right side.
Factory specs are quite wide on the camber angle.
The factory spec is +0.50 degrees to -1.00 degrees camber -- at least as per my 1995 Factory service manual.
In my experience, running the negative camber higher than -0.50 degrees has caused faster inside tire wear. There are many variables to consider which include the following:
1. Toe angle (Some people like to run a little "toe-out" on the alignment to help with steering response. Of course; this creates more friction between the tread and the road, and especially on the inside edge when running a lot of negative camber.)
2. Overall stiffness of suspension. (A firm suspension puts more load on the tires in the turns and under braking, and specifically on the inside edge when running a lot of camber)
3. Firmness of tire sidewall. (A firm sidewall can focus more weight onto the edge of a tire if the negative camber is too high.)
Old Oct 31, 2003 | 09:41 PM
vsamoylov
i got a camber kit of tirerack.com for my max. camber kit helps it alot. you could allign the wheels. i tried cornering without the kit and with it and there was a huge difference.
James92SE
142
Jan 2, 2024 09:23 AM
Apr 16, 2020 05:15 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
MannyMonroe
Sep 25, 2015 12:38 PM
adamgalazka
Sep 8, 2015 01:27 PM
