cylinder 1 misfire, need help
Old Nov 3, 2003 | 06:39 PM
dipitydoo's Avatar
Having a problem with a cylinder misfire (cylinder #1). I replaced the plugs about 2 months ago, and when I took it out, I found it was soaked in oil. I replaced it, and it still didn't work. I put in a new coil pack, still missing. Not sure what else to do. Interestingly, when I ran the check engine codes, I got a 0603 and a 0406. 0603 referred to cylinder 6, but I checked all the plugs, and cylinder 1 (near the firewall, closest to the passenger side) appeared to be the problem. the 0406 code is undefined. Any ideas?
Old Nov 3, 2003 | 06:43 PM
Jatan's Avatar
Fuel injector?
Old Nov 3, 2003 | 08:47 PM
Nismotic's Avatar
Always sunny in philly
i had the same problem once i changed the spark plugs...cyliner 1 misfire. but once i drove it down to the garage the code came up and the checks were done, but nadda.
maximas=mysterious
Old Nov 3, 2003 | 08:54 PM
dipitydoo's Avatar
maximas=mysterious
Mine worked fine after the spark plugs were replaced. This problem just surfaced about a week ago. I changed the coil pack, but the problem still persists. I'm thinking it has something to do with the oil on the plug. The plug was pretty much covered in oil, but apparently a brand new plug didn't relieve the problem. And I don't believe its the fuel injectors either, though I can't say for sure. I had the injector for cylinder 1 replaced a couple years ago, and I've been using premium fuel and fuel injector cleaners on a regular basis since then.
Old Nov 3, 2003 | 09:35 PM
95bluse's Avatar
Sounds like an injector issue to me. I just changed mine a few weeks ago. Almost changed the coil pack in error too. Mine had the mis-fire, but that disappeared on my drive to the mechanic the next morning. We changed it out anyway and car has been fine ever since.
Old Nov 3, 2003 | 11:03 PM
dipitydoo's Avatar
Are all injectors the same or are they different for the front and rear cylinders? Reason I ask is because if it is the injectors, I can get one for real cheap at a junk yard, but I heard it is a lot easier to pull the front ones as opposed to the rears.
Old Nov 4, 2003 | 04:37 AM
Jatan's Avatar
You can see the front 3 and remove them easily, but for the rear 3 you have to remove the intake manifold
Old Nov 4, 2003 | 05:19 AM
slop00's Avatar
If you have oil on your plug then check your valve cover gasket.
Old Nov 4, 2003 | 11:48 AM
Jatan's Avatar
When I did my tuneup, one of the plugs had lots of oil and another had a little bit of oil and the other 4 were fine. How do you check the valve cover gasket?
Old Nov 4, 2003 | 05:30 PM
dipitydoo's Avatar
My car is getting worse now. Today, after fueling up, all cylinders fired up for the first time since my problem started a week ago. After reaching my destination, I turned off the car, and when I tried to restart it, the car would start up, but the rpm wouldn't hold at idle. The car starts, but the rpm would drop immediately and the car would die unless I gave it gas. What gives?
jmlee44
Oct 2, 2022 02:13 PM
knight_yyz
Nov 1, 2015 01:34 PM
zmcneely13
Sep 26, 2015 02:26 PM
