Problems changing MT oil.
I tried to loosen the drain plug, not happening. I tried to take out the sensor thing and it broke by the bolt but won't come out. Any suggestions besides taking it to a transmission shop.
my drain plug is also stripped so I drained it from the sensor. after you unscrew the bolts, I just wiggled it side to side until it comes out, It has a rubber gasket on there so you may have to pull and wiggle on it to get it loose, maybe use a flathead screwdriver and carefully pry up on it without damaging the plastic housing or gasket. I think the only other option is to remove an axle and drain it from there but thats probably the last resort.
How does the drain plug get stripped? I thought you just used the end of an extension in the opening? I ask because I plan to do this soon and don't want to end up like you guys.
Just did mine last night...No problem at all. I m not sure how your drain plug got stripped, but it was very easy to remove . Not sure if some narrow vicegrip would work...It would help if you securely raise the car a little. I kept the car up until the oil drained completly. After that I leveled the car an filled the tranny. I used a clear plastic tube (2 ft from Lowes)& a funnel to fill. First 4 qts were quick, after that i filled up very slowly (expect some oil to seep when done). It takes about 4.5 qts.
I would say that it may be a good ideea to replace a stripped drain plug with a new one.
markevans999
Sep 10, 2015 04:29 PM
sdotcarter
Sep 2, 2015 09:53 PM
