please help
Old Nov 13, 2003 | 04:09 PM
maximka's Avatar
please help
i dont know if anyone asked that before, but does anybody know how to take a door panel off a 1995 maxima, i would try it my self but i dont want to screw it...
something is lose inside, that makes noise, i just want to fix that
thanks
Old Nov 13, 2003 | 07:41 PM
big_al's Avatar
Look in a haynes repair manual. Its got some pictures to help you too.
Old Nov 13, 2003 | 08:18 PM
ivelweyz
go to the audio forum, they should help you. Or search the audio forum, since you have to remove the panels to get to the speakers instructions should be there. Start with the screw inside the door "cup" thing on the armrest...
Old Nov 15, 2003 | 12:48 PM
maximka's Avatar
thanks to all of ya !!!
Old Nov 15, 2003 | 01:09 PM
erty67's Avatar
Decal Specialist
it's not too hard....there are three scews that hold it in. two on the bottom of the panel and one in the armrest(whee you stcik your fingers to pull the door shut). Once you take the three screw out, pull the armrest finger piece out. Then the hard part...taking out the piece behind the door handle. carefully pry the top of it out with a screwdriver. if you pry too hard you may break off the clip that holds it, so be careful. One you get the top loose, the other two clips should pop out pretty easy. Once you have those two plastic pieces off, the carfully pull the panel away from the door. there are plastic clips that hold it on. they should come undone fairly easily. just start in a bottom corner. check out the car audio forum. there is a site listed in the FAQs that tells you how to remove a door speaker. Good luck.
