bad gas mileage
Old Nov 15, 2003 | 08:58 AM
jrchilin07's Avatar
bad gas mileage
i jus purchased a 97 white maxima se auto.. it seems like im getting bad gas mileage... i have no check engine lights on or anything.. i checked the forums and couldnt find any answers.. does any 1 kno what it could be.... or any 1 that lives in the brockton, whitman, hanson, bridgewater area or anywhere around this area that could check my car out?... thanks and sorry for posting on a topic thats discussed so much..
john
Old Nov 15, 2003 | 09:23 AM
Jepht20's Avatar
Custom User Title...
check your tire pressure? last time you changed your fuel filter? last time your car had a tune up? knock sensor doesn't always throw a code...sorry if that's not really a help, just some places to start.
Old Nov 15, 2003 | 09:29 AM
Frank Fontaine's Avatar
john
Put in a new air filter--there is a good chance you will see an improvement. I have the K&N which is kinda bogus, but since I have it, I clean it every oil change. I always find stuff trapped in the filter, mostly from trees, those little furry seeds or whatever. I think it kills the mpg--I've seen it as low as 24 mpg highway when not cleaned. Good luck.
Old Nov 15, 2003 | 10:06 AM
jrchilin07's Avatar
if u say that the k&n is bad.. then what kind of airfilter should i get?.. im new to this... thanks ( ;
Old Nov 15, 2003 | 11:57 AM
MikeF's Avatar
Not sure if this will be much help, but I just bought a used Mitsubishi Diamante, (2001, 26,000 miles) that got terrible milage for the first few months (14 city, 20 hiway) but after about 2 or 3 months, it improved to 18/25. I can only guess that because it wasn't driven, that the oxygen sensors were a bit slow or something of that nature.
I had taken it to the local dealer, and they didn't really care because there were no codes in the computer.
As was mentioned before, check the air cleaner and put a new (stock type) in and see if it improves. Also, you need to consider how you drive it.
Mike
Old Nov 15, 2003 | 02:41 PM
Jatan's Avatar
Do a full tuneup using NGK plugs. Check the ECU for the knock sensor code (it's a ghost code so it won't turn on the CEL)
220k+ A32
18
Sep 22, 2015 11:39 AM
Maxxx10
Sep 13, 2015 03:16 PM
sdotcarter
Sep 2, 2015 09:53 PM
