Transmission replacement Question - (5-speed)
OK,
Going to be putting a remanufactured 5-speed in my car soon.
I called my Nissan OEM parts source & they informed me that there is no "transmission gasket" per se, for when the transmission is removed & replaced.
(Makes sense I guess, since I don't see the edges of an old gasket in there now).
MY QUESTION:
Should you use a sealer like "Form-A-Gasket" on the mating surfaces (bellhousing/engine block) when re-installing? -Or is this not done?
Also, I ordered two axle seals (L&R) for the new tranny - will I need any other seal/gasket parts to do this job? (I've heard people mention the "rear-main seal," before, but not sure if this is something I need to worry about.
Thanks in advance,
-K-
MY QUESTION:
Thanks in advance,
-K-
Originally Posted by MikeF
There is no fluid that it needs to retain. Mike
Originally Posted by Nismo
no no, you use Permatex gray sealer for the tranny HALVES.
There is no gasket or sealant for the tranny to engine.
Pleeeze clear this up for me.
Wow, you learn something new everyday!
Oh, and what about the rear main seal?
TIA,
-K-
yes, the whole tranny is 2 pieces together- one half is the bell housing part that bolts to the engine and the other half is the part that contains the gear sets and fluid-thats where you want to use permatex gray to seal those 2 halves together.
The bell housing half is what contains the clutch assembly and is completely dry in there so theres no need for a gasket. Yout bolt that to the engine dry.
CorollaULEV
30
Aug 9, 2021 08:11 PM
