Lowering with a kit
Old Nov 16, 2003 | 08:44 PM
Oblongshapes's Avatar
Lowering with a kit
Could you pull off the 2" sprint lowering springs and a skyline kit without leaving 650 dollars on the road?
Old Nov 16, 2003 | 08:54 PM
foetray's Avatar
Depends on the size of tires and wheels. 17's & 18'sw/low pro's is iffy. You may run into a couple of driveways or parking lot entrances that do you in. I went up to dubs with no springs and have found a couple that give me problems. I would put the kit on the car first and judge how much to lower from there.
Old Nov 16, 2003 | 09:21 PM
MaximaEvolution's Avatar
Check out this guys drop. He's got an air suspension kit, but its still pretty low with the body kit. If he's ridin like that, 2' with a kit should be fine.
http://www.vqpower.com/v2/modules.ph...ticle&artid=22
Taken2DaMax's Avatar
I wouldn't do it...it seems too low to the ground. For a car that has fiberglass up front, you wanna leave a couple of inches for anything that might be on the road.
Old Nov 16, 2003 | 10:40 PM
foetray's Avatar
That guy has bags which means he can raise his car if he runs into trouble spots. That's what I would do if I planned to lower mine that low. But I wouldn't go that low with just a simple spring setup.
JonBlz
Oct 5, 2015 06:02 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Garrettz459
Sep 28, 2015 02:50 PM
Pied
Sep 26, 2015 03:29 PM
