AEM bypass valves
Old Nov 22, 2003 | 04:54 PM
crajner's Avatar
AEM bypass valves
does anyone know if you can put an AEM bypass valve on other cold air intakes? i haven't found a AEM cold air intake for my max and i want to make sure i have that bypass valve on the intake before buying the valve and the intake.
Old Nov 22, 2003 | 06:04 PM
NissanSE98's Avatar
I dont think they make and AEM intake for maxima ----or you may have to just find one that fits-i have seen some sites where a max had aem but i never could find one--just get a chaep one off ebay---as for the valve ....its crap--you have to cut your intake in half and put the valve(not really a valve) in between--and all it is, is foam..supposedly water is supposed to collect there if any gets into your cai filter---my friend has one in his integra and its not worth it! But if you wanna waste your money you could probably fit one on there--if your intake is 3" just get the bypass valve at 3".--i have had a place racing intake for over a year and have had NO water problems!---if ur filter does get wet it will just pull air through the dry parts of the filter(which have less resistance)
Old Nov 22, 2003 | 10:18 PM
ZuMBLe's Avatar
The bypass valve is not just foam. It's a ring with multiple rubber flaps that stay closed when there is no resistance in the tubing. Say you submerge your filter completely in water. The resistance causes air to be pulled in from the bypass rather than the filter which is further down the intake stream. This causes a loss of suction down stream from the bypass valve. So, water is NOT supposed to collect at the bypass valve. It would never get that far. Now go smack who ever told you water is suppsed to collect there.
ZuM
Old Nov 22, 2003 | 10:27 PM
ABK's Avatar
ABK
you can go by AEM bypass valves seperatly, and just cut into your CAI and hook it up.
Old Nov 23, 2003 | 09:30 AM
kenji's Avatar
What would stop you from just putting the bypass valve where there's already a break in the intake piping, such as @ the MAF sensor?
Old Nov 23, 2003 | 09:42 AM
ZuMBLe's Avatar
Outside of maf would need an adaptor. You can't put it before the MAF cuz then air would be coming in unmetered. You car would sputter and prolly stall.
Old Nov 23, 2003 | 10:08 AM
kenji's Avatar
Okay, but besides figuring out the location, why go with the AEM? Is that foam filter any good?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2444449214
This bypass uses a K&N style filter and is half the price.. I would lean towards this one.. not to mention it connects differently than the K&N, with rubber hose & clamps. Thoughts?
Old Nov 23, 2003 | 10:11 AM
crajner's Avatar
ok thanks for all the imput but my question still goes un-answered. can a AEM bypass valve be put on another intake, such as a injen cold air.
Old Nov 23, 2003 | 10:33 AM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
Old Nov 23, 2003 | 11:02 AM
ny96max's Avatar
there is no need at all for a bypass valve on a 4th gen, unless you enjoy plowing into puddles that are 3ft deep... you will never need one. Im yet to see just one incident here on the Org with a max hydrolocking because of a CAI.
Ant
Old Nov 23, 2003 | 11:55 AM
LastBoyScout's Avatar
that max with the supercharger +CAI was the only one i remember......
blew the engine...
still no need if you drive smart and dont go in water deeper than your intake....
common sense is the name of the game.....
Old Nov 23, 2003 | 04:14 PM
NissanSE98's Avatar
ZuM
thats what i meant to say---i don't know what i was thinking
TKHanson
Nov 24, 2018 01:39 AM
05' MaximaMan
Oct 8, 2017 06:36 PM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
tardrex
Sep 11, 2015 07:35 PM
