What could cause his problem?
Old Dec 7, 2003 | 07:35 PM
ILoveMAXIMAs's Avatar
My friend has a 98 Se
About 3 months ago, he got into an accident, after which his headlights, his hood and his bumper were replaced. About 1 week ago, the driver's side foglight burned out. Tonight both of his low beams went out, and the drivers side fog light began working. His high beams are fine.
What ould be causing this? I think its either a fuse or a bad connection.
Old Dec 7, 2003 | 07:49 PM
PoePoe2797's Avatar
Maybe he replaced a fuse with one with a higher rating and it caused his bulbs to blow and/or melted some wires?? Either that or loose connections somewhere
Old Dec 7, 2003 | 08:21 PM
Jepht20's Avatar
Custom User Title...
i'd bet on loose connection or a bad ground. check the fuses though like poepoe said.
Old Dec 7, 2003 | 11:05 PM
vsamoylov
funny thing is that my top corner light (the one that turns bright when turn signal is turned on) is cracked. Water got into it and now when my light are on, it does not work. But when i TRUN MY SIGNAL ON, IT LIGHTS UP. WONDER WHY?
Old Dec 8, 2003 | 05:32 PM
worm's Avatar
are you talking about 2 different bulbs?
Old Dec 8, 2003 | 05:58 PM
ivelweyz
It's either a wrong size fuse, if so then the fog light wouldn't have came back on as the fuse would've blown. Loose connection somewhere, at the back of the fuse box maybe...
Old Dec 8, 2003 | 06:51 PM
vsamoylov
no, there is one bulb in the top corner leight and it only lights up when turn signal is turned on for that side. any reason for this?
Old Dec 10, 2003 | 04:41 PM
hotmax97's Avatar
May Because U Blew The 8watts Thingi On The Clearence Light
Old Dec 10, 2003 | 08:14 PM
vsamoylov
I fixed my problem. I took the corner light of and took the bulb off. Everything was coroded because of the water. So I cleaned everything and put a new bulb and everything works perfect now.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
