Rear Frozen Calipers, Help Please!
Old Dec 8, 2003 | 07:46 AM
JustMaxin96's Avatar
I woke up this AM to go to work and my rear calipers were frozen. My car was basically being dragged down the street so I had to turn around and call a cab. This ever happened to anyone? And how can I fix it? Please help!
Thanks,
Jason
Old Dec 8, 2003 | 08:00 AM
StygianMax's Avatar
The problem is probably one of two:
- kinked e-brake cable
-damaged brake caliper
My rear-left one seized up on me 2 months ago. I discovered the problem when smoke was pouring out from my car. When I pulled the car over, the rotor was lit up like a stove element on HIGH.
Help....rear rotor glowing red hot
(%&#!@....my brake's still grabbing!
I tried to fix it with a couple buddies but no luck. I ended up getting a re-built one as I figured out it wasn't an e-brake cable. There is one attached to each rear caliper. The end of the cable is connected to the spring-loaded pivot arm.
Old Dec 8, 2003 | 08:01 AM
mzmtg's Avatar
Minister of Silly Walks
Your calipers were frozen? Or was your handbrake frozen?
Old Dec 8, 2003 | 08:29 AM
Pappa Grande's Avatar
My rear driver side caliper was digging badly into my rotor. I too thought it was frozen, but after an enormous amount of muscle, I was able to turn the caliper and replace the pads (had to replace the rotor too).
matts95max
Apr 23, 2025 10:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
bbsitum
Sep 11, 2015 04:55 PM
beerman1378
Sep 8, 2015 02:19 PM
