Gauge needles
Old Dec 8, 2003 | 11:03 AM
GoalieKeg's Avatar
Gauge needles
So I just finished installing my guages (reverse indiglo), and the tachometer needle is getting "stuck" on the guage face itself. I believe that there is some kind of spring that pushes the needle up so it doesn't run into the face, but I don't know how to get to it to replace it. If someone has experience with this, let me know how to remove the needle to get to that spring so I can replace it!
Dan
Old Dec 8, 2003 | 01:27 PM
image's Avatar
Turn the needle counter clock wise i though? Also, u most likely will have to get the spring from the stealership.. :X or bum one off of somebody.
Old Dec 8, 2003 | 07:21 PM
maximagtr420's Avatar
did you put new guages over old ones?? if so you need to pull apart again and use some double stick scotch tape and make sure new guages are real flat, otherwise they will move and make your needles stick.
Old Dec 8, 2003 | 07:22 PM
vsamoylov
did u remove the needles to put them on?
Old Dec 9, 2003 | 11:35 AM
GoalieKeg's Avatar
No, I didn't. But I used the double sided tape for the tach, and the needle is still catching. Does anybody know how to take the needles off completely without messing up the tach position?
Old Dec 9, 2003 | 11:38 AM
Its a real pain in the A$$, i would take it apart and retape and check the needle at that point, while you have it apart. I have them on my car and i have not ran into any problems. you have to make sure the needles dont stick before you put it all back together. If i were you i wouldnt take the needle out, you are only asking for trouble.
Old Dec 9, 2003 | 12:10 PM
GoalieKeg's Avatar
Looks like I'm going to be taking my gauges out this weekend again.
Old Dec 9, 2003 | 03:36 PM
vsamoylov
it is not that hard to do. just a couple os screws and clips.
Old Dec 9, 2003 | 03:47 PM
ivelweyz
Aren't there nubs that the needles stop on so that they are in the correct position???
Old Dec 9, 2003 | 06:29 PM
Jaybe's Avatar
I had the same problem and this is what I did. The genius who made the gauges did not put the holes for screws so you have to estimate where the holes would be on the glow gauges, use a sharp object to make a tiny hole. Now use the original factory screws and screw in place the glow gauges. You should not have any problems after that.
Old Dec 9, 2003 | 06:37 PM
GoalieKeg's Avatar
Yeah, but the problem is with the needle height. I'm going to try to use some double sided tape.
But there's still my original question: how do I completely remove the stock gauges?
Miket2006
Mar 1, 2021 03:55 AM
captchaos
Mar 15, 2016 12:18 PM
220k+ A32
18
Sep 22, 2015 11:39 AM
RWCreative
Sep 21, 2015 11:01 AM
kadespraggins
Sep 14, 2015 12:04 AM
