Coolant leak seems to be behind a/c comp
Old Dec 11, 2003 | 07:11 PM
95bluse's Avatar
Anyone else had this? I seem to recall another member complaining of this issue. I haven't had a chance to get it up (on the hoist, that is ) as yet, so can't pinpoint it exactly. Can it be the water pump? Car has 225,000 miles on it.
Old Dec 11, 2003 | 07:16 PM
LudeAEM's Avatar
Might of been me. Still have the damn leak, its really small though, but still annoying.
Old Dec 11, 2003 | 07:58 PM
BSwithTF's Avatar
Sounds like the W/P. That's where my leak was. I let mine leak for almost a year before I finally changed it.
Old Dec 11, 2003 | 08:18 PM
SkyMaxGTR's Avatar
maybe you have the same problem i'm having.....my coolant is leaking from the radiator, and it sprays all over my engine. take a look at the pic on my site.
Old Dec 12, 2003 | 05:06 AM
95bluse's Avatar
Nope mine is definitely lower...leaking a lot now. Might have to fix asap.
Old Dec 12, 2003 | 05:07 AM
95bluse's Avatar
Did you change it yourself? If so how difficult? I'm going to dig out my FSM and check how to remove it.
Old Dec 12, 2003 | 05:11 AM
gtr_rider's Avatar
192.168.1.1
Dont let that stuff sit, if you do it becomes really hard to remove it.
Old Dec 12, 2003 | 05:34 AM
ejj's Avatar
ejj
The thermostat and water hose is directly above the AC compressor. If it were leaking, coolant could run down the block and drop from behind the compressor.
If not that, then I'd check the water pump.
Old Dec 12, 2003 | 07:14 AM
Stephen Max's Avatar
There is a weep hole for coolant leaking past the water pump o-rings on the side of the engine above the AC compressor. I had this back in September and changed the water pump. When I pulled the water pump out, it was perfectly fine, it's just the o-rings that lose their elasticity and take a set and eventually start to leak. The water pumps themselves are very well made and mine had no sign of bearing wear or impeller erosion (at 135k miles), so I could have saved $80 by just replacing the o-rings.
Getting the pump out involves releasing timing chain tension (I did that by removing the tensioner since I was replacing it at the same time I was replacing the pump) and using two M8 bolts as jack screws to jack the pump out. You should also change your oil after doing this since it is nearly impossible not to leak coolant into your oil sump when you pull the pump out. The Haynes manual does a good job explaining what to do.
Old Dec 12, 2003 | 07:42 AM
95bluse's Avatar
Thanks for the info, I just checked my manual and your write is spot on. I also spoke to my mechanic ( a cousin ) and he recommended taking off the timing cover and also replacing the chain as we're there. This will also fix my oil leak in that area. Think of it as a Christmas gift to my Max . Also, will do the brakes and replace cv boots...much dinero.
Old Dec 12, 2003 | 01:32 PM
Broaner's Avatar
2060lbs and falling...
Replacing the chain requires dropping the engine doesn't it. If your gonna do that you might as well drop in a newer engine. The chain itself is over $200 and you will need a new gasket.
Old Dec 12, 2003 | 02:48 PM
95bluse's Avatar
I don't think I'll drop the engine, just remove the timing cover & work from the side of the engine.
Old Dec 12, 2003 | 06:54 PM
Mishmosh's Avatar
On a 1995, I've heard of chain tensioners going bad but replacing the timing chain? Do you really think you need to? They are supposed to last the life of the car. I have the same problem but it's too damn cold to work on the car so I put in some Barr's Leak stopper and will tackle the water pump seals in the spring. Wasn't leaking too bad... about 8oz a week.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
foodmanry
Sep 24, 2015 12:02 PM
Hdnseek
Sep 9, 2015 05:55 AM
