URGENT! Hit a curb and bent front right control arm and spindle.
Old Dec 16, 2003 | 02:10 PM
Broaner's Avatar
2060lbs and falling...
Hey everyone,
One of the many reasons that I hate snow and Wisonsin is driving in the snow. Well the oher day I hit a curb and knew something was up cause it was making a huming noise. So I bring it to a local shop hopping something minor happened like threw off the alignment. Turns out the spindle, lower control arm and bearing are messed. The guy wants $500 for parts and $250 for labor. Used control arm is cheap but he can't find a used spindle. Thats $298 for a new spindle. My questions are; Is this a decent price? Is it possible for me to do myself without airtools or lift(Did spring install myself)?
Old Dec 16, 2003 | 06:29 PM
Broaner's Avatar
Bump. Come on guys. Help me out please.
Old Dec 16, 2003 | 07:02 PM
njmaxseltd's Avatar
Bearings need to be pressed out and back into your new spindle. It's not an easy job, leave it to somebody who has the equipment necessary to do it.
Suspension components are much better tackled with air tools and a lift. The nut to get the drive shaft out is on there really really tight. Your not going to crack it loose with hand tools.
Old Dec 16, 2003 | 07:09 PM
DJMaxGLE's Avatar
How fast were you going when you hit the curb? I had the same problem here in Iowa. I was trying to make a turn in a parking lot and hit a curb at around 5 mph. I took it to the mechanic asking them to check the front axle, but said nothing about a control arm or spindle. They said the axles fine, but are the control arm and spindle separate from the axle?
Old Dec 16, 2003 | 07:13 PM
ManualMaxima's Avatar
5th Gen till she dies!
also you might want to check the steering knuckle....i do nto kwno what to tell you about the other parts.
Old Dec 16, 2003 | 08:54 PM
Broaner's Avatar
I was going about 30MPH. Slid to the side of an icy road and bounced off the curb. I didn't think it was so bad because the wheel still looked straight and it only caused a 1.5" curb rash.
Old Dec 16, 2003 | 09:04 PM
007max's Avatar
bump
did i mention i hate ice....
Old Dec 16, 2003 | 09:51 PM
iansw's Avatar
Only 210lbs of torque. No problem with a long breaker bar.
I've done it at least 5 times on my and other's maxes without any major issues.
Old Dec 16, 2003 | 10:02 PM
vsamoylov
i sell you a conrol arm if u want one and i have also the spindle if you want it
Old Dec 16, 2003 | 10:03 PM
vsamoylov
i sell you a conrol arm if u want one and i have also the spindle if you want it email me at vsamoylov@yahoo.com or pm me
Old Dec 17, 2003 | 01:27 PM
Broaner's Avatar
How much? What is shipping where do you live.
Old Dec 17, 2003 | 01:37 PM
Nismo3112's Avatar
Custom User Title
Same thing happend to me, i got a used control arm for $50 and the spindle i bought but turned out the original spindle was fine. I think my struts r bent because now the camber still wont be within spec even if u adjust them all the way, so i had to grind some metal off the strut bolt hole....
Old Dec 17, 2003 | 02:47 PM
vsamoylov
ok, you need the control arm, the spindle (the one the wheel sits on and it spins right.) is taht all cause i will sell it to you for about $280 plus shipping. it is cheaper than what the guy said to you. it is in good condition and never was bent cause car was never in a accident. i am in hayward, california andi do not know how much shipping is. i can check it out though if you tell me you are going to buy it cause i do not want to drive to fedex or ups and come back and tell you the price for shiiping and then you decide not to buy it. email me or pm me if you still wanti and tell me if you think it is too much.
Old Dec 17, 2003 | 07:33 PM
vsamoylov
oh, i forget also that if u buy it, it won't be the spindle alone. to remove the spindel, i will have to remove the bearings and too much of a problem. so if you buy it, i will send you the whole piece. email me or pm me ASAP.
Old Dec 17, 2003 | 07:46 PM
Broaner's Avatar
Well thanks for all the help guys. The guy found a used spindlel. So now its only $380 for parts. 280 plus shipping is almost $350. But i decided to go the easy route and pay up like a sucker. I had to have it done by friday because on monday Max is going in for a sound install that has been schedualed for a month and a half. After that its UDP install. I have to schedual all this stuff at once because the only time i have during the school year is over breaks. So thanks for the offer vsamoylov. Note: I did say originally the bearing was destroyed so you wouldn't have needed to remove it.
Matt93SE
May 24, 2019 02:58 PM
Jeffesernia11
Aug 23, 2015 06:09 PM
maxocar
Aug 21, 2015 12:57 AM
soon2ownmax
Aug 13, 2015 02:19 PM
laparka66
Aug 6, 2015 09:36 AM
