Removing Intake Manifold - NEED Help!!
Old Dec 17, 2003 | 06:21 PM
Ladzio's Avatar
Removing Intake Manifold - NEED Help with injector cap!!
I removed pretty much everything out of the way except for supprt brakets bolts and EGR tube unbeneith IM. I need to replace injector in cylinder 1 (on the rear bank at passenger side). I can move manifold slightly but cannot lift it yet. I was playing with support brakets bolts for an hour but cannot reach them comfortably enough in order to apply enough torque to brake them loose..
What's the trick to loosen them... I thought I will not need to disconnect EGR tube, I need only move manifold slightly to reach injector...
Guys, please help me out here
Vlad
Old Dec 17, 2003 | 06:23 PM
d_warner's Avatar
Old Timer
All I can say is make your hand fit. It's a pain in tha ***, but I just had to get back there the hard way. Maybe someone else can help you out with a trick, but I don't know of any personally.
Old Dec 17, 2003 | 06:25 PM
Ladzio's Avatar
thanks man for a quick reply, gonna go down to garage and will keep attacking those bolts, will be back in some, time maybe someone will have some ideas
KMax2988's Avatar
Try fitting a pipe or a large box ended wrench on the end of the ratchet. That should give you much more leverage to break those bolts loose. I would remove the EGR bolts as well, that will give you better range of motion when moving the manifold. While moving it around, be careful of the coolant line passing under the EGR opening as well (connected to manifold). See what that does for ya.
Old Dec 17, 2003 | 06:41 PM
Ladzio's Avatar
OK, I got them loose!!! Now it's just a matter of time to unscrew them.
What I did is I got flat wranch on the bolt and then put screwdriver on the end and hit few times with a hammer and it worked
Thanks again d_warner and KMax2988 !!!
Old Dec 17, 2003 | 08:01 PM
Ladzio's Avatar
Just one screw was holding me back from putting new injector in and it got rounded on me, I am so mad. But anyway, I cannot remove it with Philips screw driver, metal saw won't fit in there to make new "cross" and I have no drill to get the cap off,
What else could I do???
Old Dec 17, 2003 | 08:46 PM
Ladzio's Avatar
bumpity bump, don't know what to do...
Old Dec 17, 2003 | 09:34 PM
Ladzio's Avatar
Here is what I mean, sorry for the quality...
Old Dec 17, 2003 | 09:51 PM
DaThrillr's Avatar
hand saw it with the blade in ur hand.. or get a hammer and flat head and hammer the flat head onto the top of the crew to make a groove that will hopefully help u get it out......becareful not to get savings inside the lower plenum...
Old Dec 17, 2003 | 09:57 PM
crazy4maxima's Avatar
http://www.sears.com/sr/javasr/produ...&bidsite=CRAFT
get that at sears.. iut works.. i had the same problem when i took out my old injector... trust me.. its worth it..
Old Dec 17, 2003 | 10:05 PM
meccanoble's Avatar
Sports Button FTW
haha, i seen intake and i thought u just needed help with an intake. Thought i could help u....i feel dumb again
Old Dec 18, 2003 | 05:07 AM
Ladzio's Avatar
Could not fit it there (just the blade) but will try again!!
Originally Posted by crazy4maxima
http://www.sears.com/sr/javasr/prod...0&bidsite=CRAFT
That is an idea too, most likely I will run and get it after work, I have only HomeDepot in my neighbourhood so hope they have it
Yes, thread topic name is confusing for this problem that I ran into, I just did not want to litter forum with a new thread, thanks anyway
Old Dec 18, 2003 | 05:39 AM
ejj's Avatar
ejj
I've had a few of those screws round off like that. I found that I could get the screw moving with a pair of needle-nose vice grips.
James92SE
142
Jan 2, 2024 09:23 AM
bumpypickle
Sep 20, 2015 08:22 AM
bumpypickle
Sep 19, 2015 01:07 AM
Mahmuth
Sep 17, 2015 11:45 AM
