Cracked Clear corner
Old Dec 20, 2003 | 11:36 AM
MrJimmyHoffa's Avatar
Just noticed my side clear corner had a small crack in it and was letting some moisture in. Anyone find a easy way to fix this? I was just gonna take it out and let it dry then dab a little hot glue with a cu-tip over it.
Old Dec 20, 2003 | 04:02 PM
Tyrexx's Avatar
I see water filled corners all the time around here, (WI) although usually on civics with $10 APC "Type-R / JDM / Racing" Corners. ( I hear the JDM ones add 10 HP )
That hot glue thing could work but i'd use clear silicone.
Old Dec 20, 2003 | 07:22 PM
SXN's Avatar
SXN
hot glue wouldnt work...it would just fall out over time. take your corner off the car, dry it off, and make sure all the moisture is out of it. Use some RVT silicon with a q-tip/toothpick and apply it to the area of the crack, get it in the crack and everything. if its wet outside, let the corner dry and cure inside for a while. it dries after about an hour, but fully cures after about 24. Install it again...ta da
Apr 16, 2020 05:15 AM
uttadms31
Sep 30, 2015 05:24 AM
Andy29
Sep 29, 2015 05:32 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
