lights up on bumper lenses. and method of cutting stick shift for auto transmission
Old Dec 20, 2003 | 06:53 PM
ilsim1703's Avatar
does anybody's done of front bumper light on ??? and aternated signal.. if plz gimme a instruction for that if anybody knows thank you... also i am planning to cut the auto stick shift .... off ... plz reply me if anybody knows about my question... thank you
Old Dec 20, 2003 | 10:45 PM
Broaner's Avatar
2060lbs and falling...
Why would you cut your gear selector? Are you gonna short shift your auto? Thats good for .3 sec in the 1/4. Get some *****!
silvermax2k2's Avatar
Old Dec 20, 2003 | 11:04 PM
RA030726's Avatar
I'm nutty for Nissans
it looks better short. Araffio's shifters both, auto and manual, look very nice shortened.
There are a few ways to wire the bumper lights. One is to make the blinker and marker alternate with the lights on, and blink together with the lights off this requires cutting and splicing the wires. The other way
will light up the blinker housing, with the parking lights, using a new socket for a dual filament bulb.
1 http://www.seas.ucla.edu/~cheston/home.html
2 http://www.vqpower.com/v2/modules.ph...howpage&pid=53
Old Dec 20, 2003 | 11:59 PM
araffio's Avatar
Unless you are going to install an aftermarket auto shifter (i.e. Levoc) then cutting down the stock shifter would look . I cut my auto shift rod down about 1.5" to 2" and it looked pretty good. Just use a pipe cutter and make sure the inner rod stays the same height above the outter rod.
Don't listen to these guys bustin your ***** about "short shifting your auto". Cutting an auto shifter is obviously for nothing but looks. Attention to details such as this is what makes a car stand out.
-Tony
CorollaULEV
30
Aug 9, 2021 08:11 PM
trasmadean
Jan 20, 2018 05:05 AM
JoshG
21
Sep 4, 2015 09:04 PM
maxima-junky
Aug 13, 2015 09:59 AM
