technosquare ecu check engine light, any answers?
Old Dec 21, 2003 | 04:53 PM
nowskimax's Avatar
has anyone figured out the deal with the check engine light when you have a technosquare ecu? i have the 96 ecu in my 97 and it needs to get inspected in a month or so. i know many people have discussed this but i was wondering if any answers have been found.
Old Dec 21, 2003 | 05:27 PM
Jamsan's Avatar
replace your ecu, reset cel, go for inspection, replace ecu, call it a day.
Old Dec 21, 2003 | 06:18 PM
1996blackmax's Avatar
Do you still have your 97 ECU? If you do, then what Jamsan wrote is what I would do. If not try to find a used one.
Old Dec 21, 2003 | 07:02 PM
BEJAY1's Avatar
Conecarver
Yeah, us '97s usually keep our original ECU's for just that reason. If not then reset the '96 right before inspection and hope for the best. (Or even better - borrow somebody's '97 for a few hours)
Old Dec 21, 2003 | 07:58 PM
nowskimax's Avatar
yeah i still have my 97 ecu so i was planning on doing that. but has anyone found out how to fix the problem with the 96 in a 97 or not?
Old Dec 25, 2003 | 12:49 AM
DR-Max's Avatar
Forgive me if this question sounds really dumb but why would anyone with a '97 use a '96 ecu?
Old Dec 26, 2003 | 12:05 AM
MaxedOutOfCash's Avatar
Pizda Boy
Did you by any chance read the title?
Old Dec 26, 2003 | 01:51 PM
DR-Max's Avatar
Sure did, I'm not much for tweeking my car as much as most guys do here. But the title is saying that the cel is on and this guy has a 96 technosquare (never heard of that) ecu on his 97 maxima. So...why would anyone with a '97 use a '96 ecu?
Old Dec 26, 2003 | 11:42 PM
Because the only ECU's that can be modified for our cars, the 4th gens, are for the 95 and 96 model years. No one has been able to "crack" the the ECU's for the 97-99's, so people with 97 and 98 use modified ECU's from the 95 and 96's. The folks with a 99 can't swap out their computers, different ECU, more like the 5th gen ECU.
Old Dec 27, 2003 | 12:07 AM
Taken2DaMax's Avatar
It will be a long time until we find out...
Old Dec 27, 2003 | 12:17 PM
DR-Max's Avatar
ECU modification, ie: high performance chip? How else do you modify an ecu?
Old Dec 27, 2003 | 01:02 PM
JMAXIMA's Avatar
send your ECU to a place like technosquare and they will reprogram it w/ new info... ie fuel mapping... timing perhaps... and some have raised rev. limiters
Old Dec 27, 2003 | 02:06 PM
BEJAY1's Avatar
Conecarver
As to your original question the code is probably for the rear 02 sensor. The 95/96 ECU only understands a 3wire non-heated type. Your 97+ probably has the 4wire heated style. One could probably re-wire a '96 sensor into your pipe and get rid of that MIL. It's been posted before but nobody (incl me) has ever bothered with it yet.
Now that I'm going back on the chip I'll probably do it since I already have the '96 sensor lying around here.
Old Dec 28, 2003 | 12:53 AM
I don't think that the CEL on modified ECUs in 97-99 are bad for the car. It's just a pain to always see that freakin CEL on. And you will have to keep your 97-99 ECU to periodically check to see if you really have a problem with the car.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
