warspeed x bracing
Old Dec 21, 2003 | 09:12 PM
Daze4u2nv's Avatar
warspeed x bracing
there isnt that much info on the warspeed stage 1+2 bracing. does it actually work, is it hard to install, is worth the $200?????has anyone actually used it? is it superior to the RSB. any input is appreciated..thanx fellaz
Old Dec 21, 2003 | 09:29 PM
BSwithTF's Avatar
I've got them both on my car and I am very happy with it. Makes the car feel much more solid, more like a single piece of steel instead of a front and a rear. I had Warpspeed install mine when they first came out.
I felt it made almost as much difference as the RSB, just not in the same way. Like the RSB helps with body roll, the SFC's give the car a firmer, more rigid spine. (If that makes any sense.)
Old Dec 22, 2003 | 06:32 AM
Daze4u2nv's Avatar
would ir be just as effective to put stage 2 alone cause to me stage one doesnt look like it does much
Old Dec 22, 2003 | 06:33 AM
Daze4u2nv's Avatar
it* sorry damn keyboards
Old Dec 22, 2003 | 07:15 AM
Anachronism's Avatar
The stage two bolts on to the stage one, so you need the stage 1 first. From what I have heard the stage one makes the biggest difference. I have one and two but have never tried it with one only.
Old Dec 22, 2003 | 08:10 AM
Ludacris's Avatar
Do you get less rattles, etc. due to the drop in chassis flex? This is the next main mod I would like to get..
Old Dec 22, 2003 | 10:26 AM
BSwithTF's Avatar
Yes, 1 must be done alone with 2. I had both done at the same time but Dave B did them at different times and said he still felt a difference with the Stage 2. Stage 1 basically helps with straight front to back flex and Stage 2 helps with diagonal flex.
There are less small rattles. This was great for me cause little rattles drive me absolutely insane!!!
Old Dec 22, 2003 | 02:48 PM
Daze4u2nv's Avatar
anyone know whihc helps out more the RSB or the Xbraces. cause ive read about the RSB making a car tailhapppy
Stagnet04
Sep 14, 2015 11:28 PM
MaxStock
Aug 14, 2015 10:01 PM
MaxStock
Aug 14, 2015 09:59 PM
MaxStock
Aug 8, 2015 01:18 AM
