replacing knock sensor with a resistor
Old Dec 26, 2003 | 09:38 PM
urmab's Avatar
Im tryin to replace my knock sensor with a resistor i know what the resistor should be 550Kohms right? well my question is wat voltage should the resistor be? Thx
Old Dec 27, 2003 | 04:16 AM
twiggy144's Avatar
Suggest you turn on the engine and probe the voltage at the ks connector, if you have a multimerter or voltmeter. With the impedance at 550 K ohms, I assume the voltage is 12 V.
Old Dec 27, 2003 | 06:27 AM
Jime's Avatar
The question should be wat wattage should the resistor be, they are only rated by resistance and wattage.
1/4 or 1/2 watt will work fine.
mrc00l88
Jan 25, 2024 01:14 PM
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
maxinout93
Aug 20, 2015 02:17 AM
silver_i35
Aug 3, 2015 11:20 PM
