Car runnin sluggish don't know why?
Old Dec 30, 2003 | 11:09 AM
G1Max's Avatar
About a year ago i installed a used motor from a 99 max with 60k miles in my car, ran great for the first 6 months but lately has been really sluggish. I have the pop charger air filter, underdrive pulley, and G-reddy exhaust on it, last couple of months my car has been running really sluggish, I even lost a race against my buddy who has a stock 95 max. I did a tuneup, and a complete motor-vac/fuel line cleaning, didn't help. If anyone has had any similar probs or ideas, let me know be much appreciated. Thanx
Old Dec 30, 2003 | 11:26 AM
matty's Avatar
could be the knock sensor...run the CEL even if the light isnt on...the Knock Sensor code is a ghost code and wont trip the light
-matt
Old Dec 30, 2003 | 11:38 AM
dss42's Avatar
is the TB clean?
Old Dec 30, 2003 | 12:19 PM
G20Flyer's Avatar
Always check ignition components
Plugs, wires, coils and possibly alternator.
Then fuel system...fuel filter, fuel pump, then injectors.
Old Dec 30, 2003 | 12:45 PM
Max Noob's Avatar
dirty tb doesnt lagg the car noticably.. jsut helps with throttle response.
just check your cel first..then get back to us..im thinking knock.. bu now most maxima knock sensors are going bad. alot of poeple are posting about it.
Old Jan 5, 2004 | 05:58 AM
G1Max's Avatar
I haven't heard anything about the knock sensors going bad, I would figure that would trip the check eng light, right now it is not on. I wonder if my cat converter is clogged, might have to check that. Thanx for the replies.
Old Jan 5, 2004 | 06:15 AM
speedemn's Avatar
Bad knock sensor will not necessarily trip the CEL. Check the codes anyway. That is more likely the culprit rather than a clogged cat.
Old Jan 5, 2004 | 06:22 AM
G1Max's Avatar
Got to change my oil this week anyway so I might as well run a scan test, do you think a knock sensor would attribute to a rough start sometimes? Ever now and than I get like a hesitation and the check OIL light flashes for a quick second when I am starting the car.
Old Jan 5, 2004 | 06:24 AM
speedemn's Avatar
Possibly fuel pump... or starter, but try this - turn your key to the on position and wait a couple of seconds and then crank it. See if it starts any faster. If so, then it might be fuel pump... no biggie. A lot of gen 4s do the same thing.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
acw
Aug 7, 2015 04:20 PM
