cutting stock shifter
Old Dec 31, 2003 | 11:17 AM
wrongway15's Avatar
i am probably gonna cut my stock shifter shorter and add a different shift ****...how do i get that know to stay on straight (anyway besides taking it to a machine shop)...and how hard is it to remove the shifter and replace w/o screwing anything up?
how much do most people typically cut off the top? 2in?
thanks
Old Dec 31, 2003 | 11:40 AM
Nazgul350r's Avatar
thanks
Why would you cut your shifter? STS's are the same lenght as a the stock, but he pivot is in a different location.
Old Dec 31, 2003 | 11:46 AM
MrEous's Avatar
^ Jeff™
Because there are a lot of DIY people on here that don't have the $$ for a quality short throw shifter.
Myself not included...I love my B&M, it was worth every single penny.
Old Dec 31, 2003 | 12:07 PM
skeelo34's Avatar
personally I liked the stock shifter cut. it felt nice and small.....but the good thing about the sts is that it makes the shift smuch smoother. also if you cut it, just buy one of those shifters that have 3 screws around that tighten on the rod. i had a momo cobra.....now its just collecting dust....
Old Dec 31, 2003 | 12:55 PM
wrongway15's Avatar
i wanna do it to make it look better...id get a sts but i dont have the money right now and it would still be too high
Old Dec 31, 2003 | 01:00 PM
mzmtg's Avatar
Minister of Silly Walks
PM plurco about his cut stock shifter.
He cut 3 inches out of the middle and welded it back together. This has 3 main advantages:
The OEM **** still screws on
The OEM boot stays up like it's supposed to
The angle stays correct
Old Dec 31, 2003 | 01:12 PM
ThurzNite's Avatar
that's very similar to my CartBoy short throw shifter. They took 1.5" out of the middle section and spliced it below the pivot.
CartBoy was gonna make a STS for the Maximas, but there wasn't enuf interest @ $100 shipped. So he only made them for the 1st and 2nd gen Altimas. Theoretically, the Altima shifter should fit 4th gens.
Jae
Old Dec 31, 2003 | 01:21 PM
imported_2_tha_max's Avatar
I did this a few years ago. I used a imitation c/f **** from pep boys which had set screws to secure the ****. Don't forget to use lock tite on the set screws to keep them from vibrating loose. It hasn't given me any problems the last two years.
Old Dec 31, 2003 | 02:25 PM
maxspeed96CT's Avatar
The original VQ...
I bought a 25$$ shift **** of ebay and its fine. Just dont buy the aluminum one because it wil break on you . I got a S.S. one and i love it. Plus shifter isn't something to important to me that i would want to spend alont of momey on.
Old Dec 31, 2003 | 03:40 PM
d_warner's Avatar
Old Timer
Old Dec 31, 2003 | 11:42 PM
ManualMaxima's Avatar
5th Gen till she dies!
i cut mine in the car with taking ti out. i just took a ****in saw to it, and added a $30 shift **** on it. I love it. The only thing is you will never be able to get the stock one back on. Changing yoru shift ***** will never mess anyhtng up. easy as cake
Old Dec 31, 2003 | 11:48 PM
wrongway15's Avatar
i just got a brand new dremel for christmas...maybe i can use that to cut the shifter while its still in the car. i havent used the dremel much but i tried it on some plastic and bits flew everywhere...i dont want to make a huge mess...hmmm
im also really interested in cutting out a center section to keep angles the same (tho ive never seen the shifter out so i can only imagine what i think plurco and Cartboy? did)
Old Jan 1, 2004 | 02:02 AM
plurco's Avatar
Yes I did this and it is wonderful. The throw is shorter because the shifter is shorter, and it is more stable due to the distance between your hand and the pivot point. My hand rests perfectly on the shifter now. (I am a closeup driver, no gangsta lean for me) IT is stock so it will operate more reliably than most aftermarkets. THe final touch on this will be to add a stiffer shifter spring. This should make it feel just like a 350Z shifter :-)
Old Jan 1, 2004 | 10:23 AM
Dave B's Avatar
Not DAVEB the parts guy
I've had the Pacesetter STS and B&M STS and I'm back to the cut shifter and much happier. I cut 1.5" off the top of the shifter and added an alunimum shift **** that adds some nice weight to the shifter. I love the feel and the reduced throw plus the shift pattern stays in the stock location instead of moving forward like the other shifters.
Dave
Old Jan 1, 2004 | 11:24 AM
Titan14's Avatar
cut 2" off.... make sure you get the 3 screws on the right way and you'll be fine
Old Jan 3, 2004 | 02:55 AM
ThurzNite's Avatar
wouldn't a dremel be messy if the shifter's still in the car?
Jae
Old Jan 3, 2004 | 09:54 AM
JeEvE's Avatar
I cut 1.5 off mine and I am very happy. I cut mine with a dremel and it wasnt messy at all. I put a hole in the bottom of a bag and slided it over the shifter then taped it. While dremeling I just pulled the bag up to catch all the little peices.
stock height
cut 1.5in
Old Jan 3, 2004 | 12:16 PM
MaxiSpeed97's Avatar
looks alot better, i think i might try that
Old Jan 3, 2004 | 12:17 PM
wariow's Avatar
stock height
cut 1.5in
Nice guide, I think I'm gonna do the same now and just purchase a shift **** for like 30 bucks. THanks!!
Old Jan 3, 2004 | 12:25 PM
Keith P's Avatar
[QUOTE=JeEvE]I cut 1.5 off mine and I am very happy. I cut mine with a dremel and it wasnt messy at all. I put a hole in the bottom of a bag and slided it over the shifter then taped it. While dremeling I just pulled the bag up to catch all the little peices.
[IMG]
Did you cut down the E brake handle? I am tired of bashing my knee cap!
Old Jan 3, 2004 | 01:44 PM
JeEvE's Avatar
The ebrake handle isnt cut, I doesnt get in my way so Im just going to leave it alone.
aw11power
Oct 10, 2021 04:57 AM
Fbana41
Aug 29, 2016 12:18 PM
05RLS2
Apr 14, 2016 11:49 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
atriuum
Sep 28, 2015 01:19 PM
