courtesy light is out fuse prob?
Old Jan 2, 2004 | 09:54 AM
aznpo1o's Avatar
I changed the bulbs in the courtesy light and one of them went out and wont light up . I tried other bulbs and they did not light up either, any idea how I can fix this? can I just change the fuse or something?
Old Jan 2, 2004 | 09:56 AM
Charcoal95GXE's Avatar
mine did the same thing..open up your fuse panel..on it it says INT ILLUM i BELIEVE or someting to that extent...my car did the same thing...it was just a fuse
-Brian
Old Jan 2, 2004 | 10:19 AM
Max96LSU's Avatar
is there a specific fuse for the ignition ring? I changed the bulb the other day but it still won't light up.
Old Jan 2, 2004 | 10:47 AM
JS MAX's Avatar
yeah mine was similar..just one side went out when I was checking it out and wont light back up..fuses are fine. I'm stumped
Old Jan 2, 2004 | 10:50 AM
Speebs's Avatar
I aim to misbehave.
Eek. I also had this problem but it wasn't anything as simple or as pretty as a blown fuse. If you accidentally shorted out the circuit (maybe with a screwdriver ro something.. I know the bulbs are hard to get out), then you might have fried your door switch on that side of the car. Sooner or later it's going to start freaking out and not roll up or down the windows sometimes, and the locks will also behave erratically. The only solution is to get a new switch (~$90 from dealer).
Jamie Bowen
Sep 6, 2015 09:59 PM
pktaske
Sep 4, 2015 08:40 AM
mikebla
Sep 3, 2015 05:37 PM
