Got a few codes need some help
Old Jan 4, 2004 | 08:56 AM
dss42's Avatar
1305
Fuel Pump Control Module
0210
Diagnostic Trouble Code 0210 points to a problem with the fuel injection system. When the engine management system is running in closed-loop mode the Engine Control Unit (the computer) makes continual adjustments to maintain the air-fuel ratio near the ideal point. To achieve this it relies on signals from many sensors including the Mass Air Flow Sensor and the Oxygen Sensors.
This malfunction is detected when the ECM finds that it cannot properly control the air/fuel mixture, and the mixture is too lean (too much air). DTC 0210 indicates this problem exists on the left bank (the front bank, cylinders 2, 4, and 6). Possible causes include ...
- Intake air leaks
- Front Oxygen Sensor
- one or more fuel injectors on the front bank
- exhaust gas leaks
- incorrect fuel pressure
- lack of fuel
- Mass Air Flow Sensor
I think I have a leak next to the front cat because when you rev it you can hear it couphing up from there..
Could that be causing these 2 codes?
I changed my front left bank oxygen sensor code still came back on..?
My car idles really loud also when I come to a stop It will stay at 1k then drop to 7.5k Very wierd can anyone tell me what to do first?
I am thinking of getting a ypipe and a race pipe for the leak will that fix my codes?
I just had the TB and Manifold cleaned changed the head gasket these problems started to heppen after that.
Old Jan 4, 2004 | 03:44 PM
dss42's Avatar
bump.....................
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
