compression question
Old Jan 5, 2004 | 06:19 AM
cardana24's Avatar
Blown
1-210
2-210
3-210
4-211
5-215
6-211
These are the compression #'s I got yesterday when checking my compression. I have a 98 with 122k. My question is, is this good? Is this bad? I am not sure if this is too high....my haynes manual says that 185psi is normal, and there should not be more than a 14 psi difference between the cylinders...can some one please shead some light on the numbers I got.Thanks.
Carson
Old Jan 5, 2004 | 06:26 AM
speedemn's Avatar
Your engine is fine - as long as the numbers are within 10psi of each other, which in your case, they are.
210 is quite high... what kind of a compression tester did you use? Did it have a tip that you had to screw on before you inserted it down the ignition chamber?
Old Jan 5, 2004 | 08:35 AM
cardana24's Avatar
Blown
it was my friends' compression tester....it had a blue hose and screwed into the spark plug hole, with a gauge that you could pop on and off of the top...I checked each cylinder twice for accuracy. Whlie testing I had all of the spark plugs out and and the throttle hung wide open....I guess I am just wondering if this is "too" high, haynes says that carbon deposits can make it "too" high...but they dont give you a number for "too" high....any info would be great
aw11power
Oct 10, 2021 04:57 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Socalstillen
Sep 26, 2015 12:01 PM
