Starter fixed for free!
Old Jan 7, 2004 | 09:55 PM
Wrightsfd's Avatar
My starter quit yesterday and I went to Motorvate.ca to view Frank's instructions on the rebuild. I disassembled the starter motor and gears, cleaned and regreased them and put it all back together and the thing works perfect! The moral is the next time you have a starter issue, try the regrease instructions located here: http://www.motorvate.ca/mvp.php/516 before spending the $$$ on a new unit. Only basice mechanical knowledge and socket set are needed.
K Wright
LA,CA,USA
Old Jan 7, 2004 | 10:02 PM
nismos14's Avatar
§è~® f®ÈÄk
congrats
Old Jan 7, 2004 | 10:06 PM
Maxima99SE's Avatar
will fly for food
I gotta do that soon... looks decently simple
Old Jan 7, 2004 | 10:09 PM
PoePoe2797's Avatar
I've done this so many times, I can get to the starter, remove it, dissasemble, regrease, reassemble, and completly reinstall in less than 1/2 hour
Old Jan 8, 2004 | 12:01 AM
matty's Avatar
just buy a new one...Mine used to do that starter noise way back, i shelled out the 130$ and got a starter...
those instustions will fix the noise not a dead starter like you said you had ??
Old Jan 8, 2004 | 04:05 AM
Maxima97'SE's Avatar
Thats a very helpfull site. Thanks for sharing. Maybe when I'm down there replacing my speed sensor I should regrease my starter motor. Just a little preventative matienence. Nick
Old Jan 9, 2004 | 07:53 AM
SLO's Avatar
SLO
I just recently started to get the whining noise on the starter. How do I know if it's a lube problem or just a bad starter? The noise does not occur all the time.
slo
Old Jan 9, 2004 | 08:33 AM
shuefu's Avatar
I get a whining noise only on days where there's moisture in the air (rain/snow). After 10 minutes of driving, the noise goes away. Would this be more likely my belt making the noise or the starter?
Old Jan 9, 2004 | 09:13 AM
PoePoe2797's Avatar
You should only here a whining only when starting the car (maybe a few seconds after). If it's a continuos whine for liek 10 min, its not your starter. If the car starts fine, but you here a high pitched grinding for 1 second after, you need to relube. If your starter fails to starts, try to remove, disassemble, and sand the contact points. If you need extensive help, PM me...I've done this plenty and plenty of times
Old Jan 9, 2004 | 10:27 AM
shuefu's Avatar
It's most likely my belts then. Do you unplug your battery when you take off your starter?
Old Jan 9, 2004 | 10:29 AM
PoePoe2797's Avatar
Of course! You dont want that thing trying to start accidentally when your sticking your head down there trying to get it off
lux97Max
Sep 28, 2015 11:18 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
Hdnseek
Sep 9, 2015 05:55 AM
