Airbag Control Unit Help pls!!!
Does anybody know where i can get this item pretty cheap? Dealer wants $1000+ for it. Or if you have any experience on this part pls let me know. All of a sudden my Airbag indicator just started to blink so took it to the dealer and they diagnosed it with a bad Airbag Control Unit. Pls help.
Thank you!
Thank you!
Thank you!
Thank you!
Open the driver's door. Note the rubber covered button located low on the B pillar, a button which is pressed by the door when the door is closed. This is the Driver's Door Switch (DDS).
Turn the ignition from OFF to ON. Press the DDS at least 5 times within 7 seconds after turning the ignition switch ON. Turn the ignition OFF. Close the driver's door. Start the engine
worldwiderecognized
Sep 30, 2015 01:16 PM
