is high idle after cleaning the TB normal ?
Old Jan 20, 2004 | 01:33 PM
nick's Avatar
Just simple answers please
Today i finally got around to clean the throttle body and also i've changed
the fuel filter.
Well after i started the car and than put it in gear i've noticed nice smooth idle
and no more steering wheel shaking,
but when in Neutral the idle stays around 1000 rpm's
BTW i'm auto.
Before i had very low idle - at stoplight in Drive it was around 500rpm's
in Neutral it was 800rpm's
During the TB cleaning i connected the MAF sensor and started the car and sprayed the cleaner inside the TB - check engine light came on
than I reseted it - could it be the cause of high idle ?
I've read somewhere that after resetting the ECU it can idle rough for a while.
thanks
Nick
Old Jan 20, 2004 | 03:27 PM
5KyL1N3's Avatar
I just cleaned my TB also and I too, have a high idle. 900 rpms in Neutral and 750 in Drive from a usual 750 in Neutral and 550 in Drive.
Old Jan 20, 2004 | 04:04 PM
Maxima 504's Avatar
adjust the idle, i had to do this after i cleaned mine too
Old Jan 20, 2004 | 04:28 PM
nick's Avatar
hmmm - what actually throws factory adjustemants off ?
and service manual says not to clean TB with any chemicals ?
Nick.
Old Jan 20, 2004 | 05:53 PM
Jatan's Avatar
When I cleaned my TB & IACV the idle did go up, but it settled down to normal level. I didn't want to mess around trying to adjust the idle so I left it alone and it became normal after like 2 weeks
Old Jan 20, 2004 | 08:47 PM
nick's Avatar
well - things are almost back to normal it idles right on the 650 mark in Drive ans around 900 in Neutral. I was bit skeptical about cleaning the TB but it does solves plenty on driveability issues
vibrating steering weel is gone
now i need to concentrate on fixing the shimmny at around 75mph
Nick.
Old Jan 20, 2004 | 09:32 PM
DAVE Sz's Avatar
Hooooooonda.....
well if it doesn't go down to 700rpm in neutral, like recommended, just disconnect the BROWN connector from the TPS while the car is running and adjust it with the plastic screw on the IACV.
Old Jan 20, 2004 | 09:37 PM
vipervadim's Avatar
I like Maximas
nick i got the same issue at 70-75 ish. any clues?
nick's Avatar
thanks , but i think i will leave this way
for some time and see how things develop.
I might burn bit more gas but thats about it.
Nick.
Old Jan 21, 2004 | 01:21 AM
Dave Holmes's Avatar
OT, but for the shimmy at highway speeds, have your tires balanced. Solved my problem when I got new tires.
After cleaning my TB, my idle comes back down after a few days.
Dave
captchaos
Mar 15, 2016 12:18 PM
bryants95max
Oct 2, 2015 12:52 PM
97_GXE
20
Sep 17, 2015 08:12 PM
ballerchris510
Sep 10, 2015 09:35 PM
sdotcarter
Sep 2, 2015 09:53 PM
