Anyone know the part # for 98 SE 5-Speed ECU?
Old Jan 20, 2004 | 08:16 PM
kingrukus's Avatar
no more maxima...
I have a 98 GXE 5-speed which is speed limited. I would like to swap in a 98 SE 5-speed ECU which does not have a governor on it. Does anyone know the part # for the 98 SE 5-speed ECU?
Old Jan 20, 2004 | 08:21 PM
RastaManMax's Avatar
You have a more extensive mod list than me
LEMAR
Old Jan 20, 2004 | 08:23 PM
kingrukus's Avatar
no more maxima...
Don't be fooled, most of it is useless. And the good stuff can't be installed yet till it warms up here. I am definitely moving to Florida later on in life.
Old Jan 21, 2004 | 06:25 PM
kingrukus's Avatar
no more maxima...
Bump!
Old Jan 21, 2004 | 06:44 PM
Broaner's Avatar
2060lbs and falling...
Why do you want the part #. Nissan will rip you a new one on an ecu. Go junk yard shopping.
Old Jan 27, 2004 | 09:59 PM
kingrukus's Avatar
no more maxima...
I want the part # to check and see whether the ECU's I will be looking at are the ones that I need.
Does anyone have this # or could they tell me where to look in the FSM?
Old Jan 27, 2004 | 11:01 PM
my99maxisnice's Avatar
There is a wire to unplug to take off the limiter.
Old Jan 27, 2004 | 11:55 PM
kingrukus's Avatar
no more maxima...
I am trying not to splice my harness. I want to swap the ECU.
Old Jan 28, 2004 | 01:08 AM
liqidvenom's Avatar
brotherhood of tq
hey kingrukus is you findout the part number could you pm the number to me cause im in the same situation that your in. I also have a 5-speed gxe that is limited and i dont wanna cut any wires and be stuck wit a cel.
Old Jan 28, 2004 | 06:21 AM
BEJAY1's Avatar
Conecarver
Took a look on on JRNissan's Mitchell site - it says #2371M-40U07RE is a 5sp SE ECU.
Old Feb 1, 2004 | 09:36 PM
kingrukus's Avatar
no more maxima...
Thanks for the #. Do you have a link to the actual site where you found this at? I may need it later on for more part #'s.
Old Feb 1, 2004 | 09:50 PM
dmontzsta's Avatar
Ford Only.
There really is no part number. I went through this in my search for my 5 speed ECU after the swap. I called several dealers, each that had different part numbers. Then www.car-parts.com and they all have different part numbers. Then I had a couple of 5 speed owners check their ECU's, all different numbers. The best thing to do is a search on carparts and hope they send you the right one, I got lucky and so did jdmmax.
Old Feb 1, 2004 | 10:23 PM
kingrukus's Avatar
no more maxima...
Damn! So this is a lot more complicated than I thought. Would you mind me asking how much you paid for your ECU?
Old Feb 1, 2004 | 10:30 PM
dmontzsta's Avatar
Ford Only.
no problem, I paid $140 shipped.
Old Feb 2, 2004 | 06:57 AM
liqidvenom's Avatar
brotherhood of tq
is the canadian ecu the same as ours, since car-part has some canadian stuff on there
MR2 T'd
Jul 9, 2021 05:06 AM
AcuraLegend
Oct 17, 2016 08:47 PM
ballerchris510
Sep 10, 2015 09:35 PM
mix master
Sep 4, 2015 05:50 PM
