Adjustable rears / non adj front struts
Is it ok to have rear adjustable shocks, and non adjustables in the front, while all struts are on sprint springs. I have agx in the rear with tockico blues in the front. Just wondering if this is ok or if anyone has done this.
scott
scott
That would be interesting to say the least, a rear end which is planted and a front end with OEM replacement struts and sprint springs. You're a pioneer for real, just swap out those blues when they blow for some AGX or Illumina fronts.
I've had this combo for while now:
- front Tokico hp's , back KYB AGX with Sprints
than i had H&R springs
and now i'm on stock SE springs - but i'm replacing the rear KYB AGX with stock SE struts
Nick
Nick
You could probably do it as long as the valving was similar...BUT I have to say that I have not messed with the AGX's on my rear that much, but I have on the front and the front makes a MAJOR difference in the handling of the car. Going from 2 -> 3 made the turn-in on corners significantly tighter...like it's on rails. All other things being equal I would rather have the same adjustable struts on all 4 corners./
Huttig2009
Sep 25, 2015 03:31 PM
kenc15
Sep 25, 2015 06:38 AM
MaxStock
Aug 14, 2015 10:01 PM
laparka66
Aug 6, 2015 09:36 AM
