how do i change the bulb in sidemarker?
Old Jan 23, 2004 | 12:51 AM
xxdean057xx's Avatar
i dont see any screws holding the sidemarker in.
Old Jan 23, 2004 | 12:57 AM
Nismo's Avatar
you have to pop them out. stick a flat screwdriver in there and carefully pry them out and they will pop off. Its held by a (ball-in-socket type deal)
Old Jan 23, 2004 | 06:19 AM
MaxedOutOfCash's Avatar
Pizda Boy
but there's a scre on top...when you open the hood...
Old Jan 23, 2004 | 08:57 AM
Brudaddy's Avatar
Mine just have kind of a twist mechanism. You know how your twist and pull to get out the bulbs that are in your clear corners(or stock bumper lights?)? that is how my side markers were.
Old Jan 24, 2004 | 07:03 PM
i bought some cheap bulbs on ebay for the sidemarkers and they are only bulbs (with no wires). i assume they are for the sidemarkers because i saw that the clear corner's bulbs have wires leading to the bulbs. hmmmm
Old Jan 24, 2004 | 07:45 PM
Nismo's Avatar
your talking about the corner lights next to the headlight, hes talking about the sidemarker/turn sig.
Old Jan 25, 2004 | 02:18 PM
yes i am , please anyone know???
Old Jan 25, 2004 | 02:25 PM
Nismo's Avatar
like I said, you stick a flat screwdriver between the corner light and sidemarker and pry it until it pops out, its held in by a ball in socket clip, no screws at all
However-the turn signal is held in by a screw that you will see once you take the sidemarker off.
Old Jan 25, 2004 | 09:41 PM
thanks for the 411 nismo also anyone know if these fit ANYWHERE?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2452184960
i m pretty sure now this guy listed the wrong bulbs for the 98
thanks
Old Jan 25, 2004 | 09:44 PM
myke321's Avatar
thanks
You can use those for your break lights too!
Old Jan 25, 2004 | 09:45 PM
Nismo's Avatar
1156 will fit the front turn signals, rear turn signals, but that would be illegal for the rear turn signals since its white
Old Jan 25, 2004 | 10:02 PM
myke321's Avatar
I thoght front and rear turn signals were 1157's scince they are singal filiment and 1156 are duals.
Old Jan 25, 2004 | 10:05 PM
SXN's Avatar
SXN
it doesnt matter if you get single or double. my stock turn signals in the back were single, and my fronts were duals.
Old Jan 25, 2004 | 10:08 PM
Tyrexx's Avatar
They are, and that's what he said.
Old Jan 25, 2004 | 10:09 PM
myke321's Avatar
This is true,but if you have Duel filliments in the frount trun signal would'nt it use the lower watt filiment when blinking? if you used 1157 for the turns, the bulb would blink brighter.
Old Jan 25, 2004 | 10:21 PM
SXN's Avatar
SXN
depends. single filliment hyperwhites are brighter than dual filliment bulbs from kragen. i do get your point.
Old Jan 25, 2004 | 10:58 PM
Nismo's Avatar
1156 is SINGLE filiment
1157 is DUAL
Old Jan 25, 2004 | 11:00 PM
SXN's Avatar
SXN
nismo to the rescue
Old Jan 26, 2004 | 03:31 AM
thanks nismo
Sir Tilus
Mar 22, 2016 01:49 PM
JoshG
51
Sep 21, 2015 10:41 PM
meccanj98
Sep 17, 2015 08:28 AM
meccanj98
Sep 16, 2015 06:06 PM
minsbang
Sep 11, 2015 08:48 PM
