Dust Boots Necessary?
Just installed KYB AGX shocks with Tein S-Tech spring. But didn't put any dust boots in whatsoever. My buddy says its not important. I only plan to use the car for road driving. Would the rain, dirt, brake dust get into the shock? I took some pictures and will post them soon, when I have some time. The drop is nuts! I need to know if I need dust boots because I will be aligning the front wheels soon.
well they should be important. Even tho I didn't order special dust boots for my new KYB struts...I put some on anyway...at the last minute. I went to autozone and got some rack and pinion dust boots that looked about the right size. I had to cut one end of the dust boot...and used tie-wraps to secure both ends. They are still working fine...but I'd recommend you use them. Dust can interfere with the seal that keeps the struts from leaking. For $5 per strut..I'm happy.
Running without dustboots is not good IMHO. What makes shocks start leaking is when dirt, mud, etc gets into the shaft of the strut. You can make dustboots fit under coilovers, you just need to find some thin boots and/or be creative with stock sized boots.
LEMAR
LEMAR
LEMAR
LEMAR
before my max, i did the 4X4 thing, and there was a bunch o' people who took the dust boots off their shocks because they thought that the boots would trap and hold dirt inside and kill the shock sooner than if you just washed 'em off regularly.
something to think about.
Also, extreme applications do not have dustboots available.
I do see your point, however.
The Piston?
How would one go about washing the shock? Would taking a sponge to the piston be good? I hope water doesn't get thru the seal. And, about how long should one wash the shock? I am a noobie, and have lot of questions, but thanks for your help.
Originally Posted by amr1776
Great idea izzydig...do you remember what size you got at Autozone?
Apr 16, 2020 05:15 AM
imported_Nismo_max
Feb 17, 2016 03:39 AM
knight_yyz
Nov 1, 2015 01:34 PM
