pathfinder TB
Old Feb 1, 2004 | 08:10 PM
plurco's Avatar
pathfinder TB
what year is compatible with our cars? I know you have to do some fabing, but which one has the same TPS plugs?
Old Feb 1, 2004 | 08:20 PM
kaptainkrunk's Avatar
what kind of gains are you looking at with the new TB? Also how much?
Old Feb 1, 2004 | 08:29 PM
plurco's Avatar
you can do the whole project for around $200, No gains have been recorded yet, but 90sleeper has one and is putting down some unheardof numbers. I plan on doing a before and after comaprison.
Old Feb 2, 2004 | 06:20 AM
plurco's Avatar
bump, come on guys help a brother out. I do realize I am not asking about buld codes to put pink LED's in you ashtray, but I am sure someone can help me.
Old Feb 2, 2004 | 06:41 AM
mzmtg's Avatar
Minister of Silly Walks
http://www.PutAPathfinderTBOnYourMaxima.com
All you need...
Old Feb 2, 2004 | 06:46 AM
plurco's Avatar
damn Ben that helped out alot!!! smarta$$
Old Feb 2, 2004 | 06:55 AM
96sleeper's Avatar
I believe it is only 2000-2001 that is compatible. It is the ones that got the 3.5VQ but still have a throttle cable, not that throttle-by-wire junk. Make sure it is off the 3.5 liter engine. I believe mine is a 2001 and I am using the pathfinder TPS, others have put the maxima TPS on the TB. Whatever you do make sure to set up the TPS correctly before you put it in the car. This procedure is listed in the haynes manual, and others I am sure.
Old Feb 2, 2004 | 07:02 AM
Nismo3112's Avatar
Custom User Title
Do you have any idleing issues at all?
Old Feb 2, 2004 | 07:05 AM
plurco's Avatar
yeah I just set up a new TPS so I know that routine. What did you notice after the install?
I feel this is an unsung mod for us N/A guys.
Old Feb 2, 2004 | 07:08 AM
Nismo3112's Avatar
Custom User Title
I'm willing to do this mod if the gains are proven..
Old Feb 2, 2004 | 07:35 AM
plurco's Avatar
I want to do this along with an AFC. I think with these two I can get 200+ fwhp along with my current setup.
Old Feb 2, 2004 | 08:24 AM
Dave B's Avatar
Not DAVEB the parts guy
I think there are some cold idle issues running PF TB. If you live a warm climate where 40+ degrees is normal it's probably no big deal, but if you live somewhere where it's in the teens or single digits, it may be an issue. I'd hate to think that starting the car on a cold day may make your idle stay at 1500-2000rpms till the motor is completely warm. If you have an auto, it could be dangerous.
Dave
Old Feb 2, 2004 | 08:53 AM
Stephen Max's Avatar
My writeup: http://forums.maxima.org/showthread....ght=pathfinder
Old Feb 2, 2004 | 10:23 AM
I30tMikeD's Avatar
I have the adapter plates sitting in my garage for the PF TB, just need to find a decent priced use TB. Yes, it's the 2001 3.5 pathfinder.
I know I am going to loose my cold start and coolant lines that go through my stock TB, but I am only going to run the PF TB in the warmer months of the year.
Old Feb 2, 2004 | 10:28 AM
96sleeper's Avatar
Dave
The funny thing is, I don't have any idle issues at all. My car doesn't stay on the fast idle at all. When it has been in the low teens here, my car acts like it wants to stumble when I first start it, but after that it is fine.
halfpol
Oct 17, 2022 12:16 PM
t6378tp
Sep 29, 2018 04:27 PM
spencerwh1
Jun 30, 2016 05:44 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
