two questions
Old Feb 2, 2004 | 03:20 PM
trubd's Avatar
two questions
My first question is about the ECU
I thought my knock sensor was dead so I was was checking for codes but I not nothing... Does that mean my knock sensor is ok? If so what could be the problem to my slow acce after initial pickup?
Second question is about the fuel filter.
I took out fuse #32 and cranked the engine couple of times to depressure the lines. I then tired several times to remove the tubes connected to the filter but no luck.. Am i doing something worng? Is there any additional steps i can do to make this process easier? Thanks
Old Feb 2, 2004 | 06:02 PM
trubd's Avatar
any1.............?
Old Feb 2, 2004 | 06:23 PM
Jatan's Avatar
Dirty TB? It could be injectors sticking. Try runing some Chevron with Techron Fuel System Cleaner to see if that helps
Crank it a few more times and pull
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
