Engine light on, now off, advice please
Old Feb 4, 2004 | 01:57 PM
sbcvulcan's Avatar
Engine light was on for a few days starting last Friday. Happened to need new exhaust from converter down cause of hole in resonator pipe and did that Sat. Light stayed on which i would have expected, now 4 days after repair,it is off. Does this mean problem is really non existent or corrected? Can the shop still test the code if no light on? Do I need to still have this checked ? Does the light go off after a certain amount of time anyways?
Just have no interest in doing something unnecessary. Could use all advice. Thanks so much.
1997 SE 5 speed
Old Feb 4, 2004 | 02:08 PM
Jepht20's Avatar
Custom User Title...
you can test it yourself. read through all the faq's and stickies at the top of the 4th gen forum. if the problem wasn't detected again after a certain amount of starts, the light will sometimes go off. if the car is running fine, i wouldn't worry about it. if it's something that needs to be fixed, it will return. hope that helps and welcome!
you'll have to come to some local mass meets. check out the northeast forum.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
Flores94
Aug 11, 2015 12:53 PM
bassmann
Aug 3, 2015 07:53 PM
