Best location for Garmin GPS V?
Old Feb 5, 2004 | 02:16 PM
95MaxSE's Avatar
Hi guys,
I am trying to locate the optimal location to install the GPS V.
1) What location works for you? If you have a picture, please post.
2) What's the cleanest way of routing the power line to the unit. Again, picture if available, please.
3) What do you need to modify in order to always have power at the ciragette lighter socket, even when ignition off.
Thanks in advance for your help.
Sam
Old Feb 5, 2004 | 05:28 PM
Broaner's Avatar
2060lbs and falling...
Haven't done this but I was wondering why you want it on all the time. What if you forget to turn it off? Sounds to me like you will have no battery. Open up the trim panel around the shifter and buddy off the cig lighter. This works perfect for anything up to 20AMPS. Run the wire through the dash and drill a whole wherever you want the unit.
Old Feb 5, 2004 | 07:13 PM
Blackwind's Avatar
i have the same thing that thing is bad a$$!!! ive been trying to locate a spot for it to.
Old Feb 5, 2004 | 07:46 PM
minsbang's Avatar
The only thing I can think of is to buy a double sided velvro sticker at Home Depot and put it right above the hazard light button.
This way, you can remove it to avoid any theft.
Old Feb 5, 2004 | 09:44 PM
Bgohan's Avatar
No velcro/tape! Cheesey!
Build a bracket to place it on left or right side of the steering wheel, installed between lower and upper dash panel. You could also install it on a cell phone bracket, like the one you can buy to install on the side of the upright section of the center console. Wanna picture?
Old Feb 6, 2004 | 07:56 AM
95MaxSE's Avatar
Yes, pictures please.
Thanks,
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
fx4five
Oct 1, 2015 04:58 AM
