Problem with Y-Pipe
Old Feb 11, 2004 | 03:32 PM
cw96's Avatar
Problem with Y-Pipe
I bought and installed a Budget Y-Pipe last week.Here's the problem my right bank oxygen senser is hitting the driveaxle assembly at the bracket.Has anyone else had this problem and if so what did you do to fix it?As of now I have installed a plug for the O2senser which really sucks because other that my check engine light staying on all the time the PCM operates in an open-loop fuel control mode which I'm assuming means my max is not running at it's optimum performance.Other than trying to find a shorter after market oxygen senser I'm at a loss.An feedback would be greatly appreciated.Thanks.
Old Feb 11, 2004 | 04:01 PM
Nismo's Avatar
not shure exactly which bracket but you probably have to buy a new o2 sensor bung and have it welded on to a better location and plug up the old one.
I had a problem with my o2 sensor (cattman ypipe) hitting a piece of sheet metal so I just bent the sheetmetal that that was it.
lrb6805
Sep 30, 2015 08:12 AM
lrb6805
Sep 17, 2015 04:49 PM
Violator
Sep 9, 2015 10:14 AM
