2 questions for 5sp owners
Old Feb 11, 2004 | 07:18 PM
SkyMaxGTR's Avatar
Hi, im just about to start my 5 speed swap, almost have all the parts needed, but i got 2 questions. first, are there 2 different ECUs between standard and automatic? if so i guess i'll need a new ecu. second, which flywheel is the best? i've seen some wieghing at a mere 5lbs, and i think i remember reading somewhere that if the flywheel is too light, then you end up launching worse then stock. and also, i've seen people with the Fidanza flywheel. How did you get that?(ok so maybe not just 2 questions lol) i went to their site and they do have an application for Maxima.
Old Feb 11, 2004 | 07:20 PM
ManualMaxima's Avatar
5th Gen till she dies!
i do not know about the flywheel but i postivly think that they are different ecu's. i might be wrong but it hink that they are.mine came 5-spd so i never did the swap to acually find out.
Old Feb 11, 2004 | 07:31 PM
Ceasars Chariot's Avatar
Old Maxima Legend
yes ecus will be different with transmissions, with my small experience in it, the auto ecu will work with manual but you get auto tranny codes cause its no longer there. but a manual ecu will not work with auto.
Old Feb 11, 2004 | 07:34 PM
Morfeus17's Avatar
Hi. I did this swap about 8 months ago. The ecu between the 5spd and auto are different, but both ecu's will work.. The auto will give you a check engine warning dued to the conversion. However the performance will not be degraded from the auto ecu.
I also have a fidenza flywheel and I have no complaints. Rule of thumb, you don't want your flywheel to light it will affect performance. 5lb fly is not recommended. The Fidenza is about 12lbs vs the 25lb stock unit.. One thing I've notice with the LW Flywheel... Your acceleration is very responsive, and your de-acceleration is also responsive.
At the time, I purchased the Fidenza for about $325. Not sure what is worth now? There are many places that have fidenza for maximas for example
http://cattmanperformance.com/
Hope this helps.
Old Feb 11, 2004 | 10:51 PM
Nismo's Avatar
different ECUs and I have Fidanza from Jeff92se
Old Feb 12, 2004 | 07:23 AM
mymaxlvsattn's Avatar
slackass
I was wondering the same question about flywheels about a month ago so i decided to do some research...
Nissan makes their flywheel semi heavy for a reason it makes the engine very smooth and enables it to retain energy at part throttle cruise and up long grades for better fuel economy. Now if you replaced the stocker with a fidanza or comparable flywheel it'll let the engine rev up very quickly and allows the engine to work easier due to the reduced weight spinning around on the back of the crank. BUT...
as soon as you let off the gas the engine RPM drops instantly and the car slows down. If you go too light this will cause cause surging and bucking at cruise speeds and poor driveability and clutch engagement. Also, inorder to move you will have to start a much higher RPM just to get enough inertia to get your car moving..
hope some of that helps..
Old Feb 12, 2004 | 07:50 AM
Flava_24/7's Avatar
Boosted Panda
Before I installed my clutch/flywheel setup I researched it and found the sam results stating too light of a flywheel would cause horrible launches. Everything I heard about Fidenza flywheels was good. It being light, but not too light.
I was set on purchasing a Fidenza. Then I came across a REALLY good deal on a Stillen flywheel, so I went with it. It is lighter then the Fidenza, wieghing around 7lbs.
I can honestly tell you that I've had no issues with it at all. My launches seem to be the same as before. I get no surging or bucking at cruise speeds.
I did also install a Exedy stage 1, so that sucker grabs really quick. Maybe thats why I havent noticed any delayed launches.
I did notice that with the lighter flywheel the RPM's do drop quicker...but the car accelerates so much quicker now.
Old Feb 12, 2004 | 10:21 AM
slackass
i just checked on the stillen flywheel....550bucks... thats INSANE!
youd think being less material it would be cheaper..too bad the world doesnt work like that
Old Feb 12, 2004 | 10:24 AM
Flava_24/7's Avatar
Boosted Panda
Exactly, thats why when I saw it for sale at a really good price (250.00) I grabbed it.
Old Feb 12, 2004 | 10:59 AM
maxima98vspec's Avatar
what flywheel weighs 5 lbs? i wounder how much that is?
Old Feb 12, 2004 | 02:47 PM
Flava_24/7's Avatar
Boosted Panda
Stillen...... http://www.stillen.com/sportscars_pr...nd=&subcat=206
Old Feb 12, 2004 | 03:02 PM
PoePoe2797's Avatar
I got a Fidanza flywheel....my car is very hard to drive cuz the throttle is so responsive that it causes surges, and lauching is very hard....and they suck in traffic.
Old Feb 12, 2004 | 03:49 PM
Flava_24/7's Avatar
Boosted Panda
Wow, I have no problems like that with mine. What clutch do you have?
Old Feb 12, 2004 | 03:56 PM
Nismo's Avatar
no problem here too, maybe you need a lighter foot
PoePoe2797's Avatar
stock...the rpms drop way too quickly so when i granny shift, sometimes its rough and driving in the city it gets frustrating trying to smooth out the roughness and trying to rev match when the RPMs rise and drop so quickly. Been driving 5-speed for 3 years, and I'm having trouble....I even stall once in a while
Old Feb 12, 2004 | 06:40 PM
Originally Posted by FLAVOR247
thanx, im gonna get it.......and see how hard it is do drive, we are all different at driving and most of us are really sensative to most things like springs and stuff like that, but not me....i get use to things quick
Old Feb 12, 2004 | 07:31 PM
SkyMaxGTR's Avatar
Thanks for all the help guys. Maybe i can find the Fidanza for alittle bit cheaper somewhere else. does anyone know anywhere else they sell them?
I think the unorthodox makes a 5lbs, and a 7lbs.
once again thanks for all the help. wish me luck with the swap.
Old Feb 12, 2004 | 07:46 PM
Flava_24/7's Avatar
Boosted Panda
When I researched flywheels I found many saying that the Unorthadox and Stillen are actually manufactured from the same Co. but are distrubuted and stamped by Stillen and Unorthadox.
SkyMaxGTR, if you want I can give you a ride and you can see how the car drives with it installed.
Ask Jeff92se if he has any available.
Mar 12, 2020 12:06 AM
Maximan190
Dec 16, 2015 06:01 AM
Krazzespiinz
Sep 13, 2015 07:10 AM
hntwhttail
Sep 12, 2015 03:43 PM
Johnny9595
Sep 3, 2015 05:18 AM
