Brake Lights not working
Old Feb 14, 2004 | 01:18 AM
wiseguy6199's Avatar
My car's brake lights do not work although I checked all the fuses and lamps!
is there anything else to check?
Old Feb 14, 2004 | 01:26 AM
Nismo's Avatar
the brake lights are dual filliment 1157 bulbs, are you shure both filliments are good? best thing is to change the bulbs anyways since Ive seen some bulb's filliments that look like that are good but yet the bulb is blown. double check the fuses too
Old Feb 14, 2004 | 02:21 AM
You mean I should check the fuses using an ohm-meter, 'cause they look good.
Old Feb 14, 2004 | 06:07 AM
myke321's Avatar
the 7.5 fuse was not broken? the only thing it can be is the bulb, wires, or fues. when my breaks went out it was the fuse that went out.
Old Feb 15, 2004 | 12:27 AM
Well, I checked everything, but do you think that the switch that is under the brake pedal is not good? !!!
jerrod99_se-l
Aug 27, 2015 08:27 PM
JMag90
Aug 25, 2015 09:17 AM
Samedi
Aug 13, 2015 04:05 PM
kenc15
Aug 5, 2015 08:29 AM
