Can UR Car drive straight?
Old Feb 18, 2004 | 07:02 PM
C3nthusiast's Avatar
I have 2 4th gens (96 and 99). they both pull left and suffer from a slight vibration. It'd been present when it was stock, lowered, w/ stock wheels and 19's, after balancing and an allignment. It just does it no matter what I do in both cars. Whats the problem?
Old Feb 18, 2004 | 07:11 PM
Conrad283's Avatar
I need a truck
Mine does for a little while ...
Old Feb 18, 2004 | 07:16 PM
Cal0205's Avatar
Yes, i recently got my STOCK car. The car can't stay straight for more than 3 sec. Am planning to take it in for an alignment.
Old Feb 18, 2004 | 07:40 PM
ManualMaxima's Avatar
5th Gen till she dies!
mine does not drive gay? yea mine is pretty good unless i have uneven pavemenr or a rut, or something like that
Old Feb 18, 2004 | 07:57 PM
Nismo3112's Avatar
Custom User Title
It depends on the pavement... in a parking lot, yes my car will drive straight, but on the road, no.
Old Feb 18, 2004 | 08:13 PM
sk24iam's Avatar
possible unequal amount of tire pressure
Old Feb 18, 2004 | 08:16 PM
felix's Avatar
Sittin' On Chrome
nope. just got an alignment done today. still pulling a little to the right.
Old Feb 18, 2004 | 08:22 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
My car also pulls to the right after getting alignment done to it.
Old Feb 18, 2004 | 08:31 PM
felix's Avatar
Sittin' On Chrome
i'm gonna go back and complain. make them try it again.
Old Feb 18, 2004 | 08:34 PM
CystumMax's Avatar
I don't think that would work, I have heard from like 2 people saying the same thing after they droped their car, it pulls to the right. but it is worth the try.
Old Feb 18, 2004 | 08:40 PM
mansurxk's Avatar
try a parking lot, roads are crowned to be even with the curbing, i know some transportation engineering, meaning if you take a string from the middle of the road, itll be even wit the top of the curb. that might be causing pull in a certain directoin, parking lots arent crowned, theyre generally flat
Old Feb 18, 2004 | 08:41 PM
felix's Avatar
Sittin' On Chrome
yeah but I told them it was dropped and the guy said he was confident that he could align it right... i guess he can't...
Old Feb 18, 2004 | 08:43 PM
optimus310's Avatar
just got my aligment done after some work on my rack and pinion. And now my car drives pretty straight going 75mph. It will go staright for few minutes, then it starts to pull really slowly
Old Feb 18, 2004 | 08:58 PM
thisasian's Avatar
http://home.earthlink.net/~maxfaq/suspension.htm#pull
My car pulls too. I've had 3 alignments in the past 2 yrs, and nothing works. I'm going to try this when I put new bushings on my front sway bar.
Old Feb 18, 2004 | 09:54 PM
boyzindahood978's Avatar
I had an alignment done not too long ago when i put on my falken's. The car still pulled to the right. I took it in for a re-alignment. Same thing. I don't know whats wrong with it.
Old Feb 18, 2004 | 09:58 PM
jlsund's Avatar
I took my 98 to a specialty guy, and he told me that lowered Maximas (and older 300z's) he has found to have a problem with pulling to the right. He had no explaination why, but the 3 people I took it too and told me it was aligned correctly sure back his claim up. the only possiblity I havent counted out is radial pull (which is unlikely, but possible, considering the car did not pull before i got higher performance tires) -my 2 cent
Old Feb 18, 2004 | 10:25 PM
Wisky97SE's Avatar
My maxima drives straight and its lowered.
Old Feb 18, 2004 | 11:32 PM
bigx323's Avatar
if ur car pulls to the right on a normal road than its normal, because thats how roads are made so that the water from the rain goes to the sides of the road and doesnt just collect in the middle. So basicall most of the roads are made like that, well at a slight angle, to allow the water to always go to the right no matter which way ur driving on the street and so hence ur car pulls to the right as wee.
and if it pools to the left u might want to check out ur motormounts as well.
Old Feb 18, 2004 | 11:38 PM
Max96LSU's Avatar
My car only drives straight when I'm not drunk!
Seriously, my car drives straight and i'm lowered.
Old Feb 18, 2004 | 11:44 PM
Sniper's Avatar
Straight as an arrow...
Old Feb 19, 2004 | 04:33 AM
thisasian's Avatar
Hello? Has anyone tried adjusting the camber like the link suggests? Anyone? Beuller, Beuller...
Old Feb 19, 2004 | 05:08 AM
Matt_NZ's Avatar
If I drive smack bang in the middle of the road, it'll go straight, otherwise it'll pull to the left (LHD roads ). Just recently had it re-aligned after it started suffering from some major shakes, took the garage two days, but they re-aligned it perfectly (as well as checking to make sure it wasn't anything major causing it)
Old Feb 19, 2004 | 05:55 AM
ohannon7's Avatar
Mine pulls left like a ****. Our springs rotate, I can spin them back into place and it will drive straight. But when im cutting the wheel sharp in a parking lot they will start to spin, and pop and my alignment goes w/ it. Anyone experience the same thing
Old Feb 20, 2004 | 02:42 PM
jlsund's Avatar
explain this spring thing to me. I was unaware that the springs had that kind of movement within the wheel well. Why does this cause pull as well, (I think this might solve a big problem once and for all)
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
yat70458
Aug 3, 2015 01:16 PM
