Quick alternator replacement question
Old Feb 19, 2004 | 07:39 PM
The_Bomb's Avatar
My alternator went out on me tonight and my Chilton says that I need to remove the fan and fan shroud to get the alternator out. But in order to remove the fan and the shroud I need to remove the upperhose on the radiator meaning I need to drain the coolant. Is it really necessary to do this? draining the coolant isn't much fun. I assumed that if you remove the belt and the bolts that is will slide right out the bottom... am I wrong? Any tips would help a lot. Thanks.
Adam
Old Feb 19, 2004 | 07:43 PM
ABK's Avatar
ABK
go out and check if you really have to remove the fan, it could be for easier access, maybe you will be able to get it from the bottom if not from the top. Even if you have to remove the fan don't worry, the upper colant hose won't allow all the collant leak out, I was replacing my thermostat almost no collant leaked out when I took off the hose (just make sure you don't open the radiator cap).
Old Feb 19, 2004 | 07:55 PM
Jatan's Avatar
http://www.motorvate.ca/mvp.php/500
Old Feb 19, 2004 | 08:37 PM
The_Bomb's Avatar
Originally Posted by JaTaN
Thanks, all of my time on these boards and I forgot about that site. It doesn't look too hard at all.
Adam
Old Feb 19, 2004 | 11:44 PM
Kanaka's Avatar
I helped my friend change his alternator in his 2k. it was pretty hard to get to the rear bolts. our 4th gens are almost identical...and just as hard. not a fun job, but doable.
PH98I30
19
Jun 13, 2016 02:38 PM
Balkins
Feb 1, 2016 12:45 AM
JMag90
Aug 25, 2015 09:17 AM
doobadoo
Aug 15, 2015 06:43 PM
classymax420
Aug 6, 2015 06:35 PM
