Custom red/clear tails
Old Feb 20, 2004 | 12:34 PM
MaxGR97's Avatar
Is it possible to make your own red/clear tails? I think i remember someone saying that they took apart their stock tails and took out the orange part!?! i dont know if this is true, so im just double checking. If so, how do you do it? thanks
Old Feb 20, 2004 | 12:37 PM
Jepht20's Avatar
Custom User Title...
have you read the faq's before?!?
http://forums.maxima.org/showpost.ph...86&postcount=5
enjoy...
Old Feb 20, 2004 | 01:03 PM
MaxGR97's Avatar
Nice, thanks, how many people have actually done this? and how well did yours come out?
Old Feb 20, 2004 | 01:17 PM
MaxedOutOfCash's Avatar
Pizda Boy
hardest part is cutting out the clear plastic, it chips like crazy.... i think mine came out pretty good....i should do the inside's too so it matches nicely....
Old Feb 20, 2004 | 01:55 PM
MaxGR97's Avatar
thanks 4 the pic and the comment, ya i think itd be nice if the two clear parts matched. So from 1-10 what do you rate the toughness?
Old Feb 20, 2004 | 07:36 PM
5spdFastMax's Avatar
The sticky reads...red/clears for 97-99, but not for 95-96 i think. Can you do it on 95-96?
Old Feb 20, 2004 | 07:41 PM
sadice's Avatar
no u can't do it on 95-96 and toughness took me an hour to do or so it is kinda hard to cut out but i found a way to make it a little easier. i took the plastic cover from the lights put it on the table drew the lines for the piece i had to cut than used heat gun to heat it up a little make it softer but pressing it down because if u won't press it down it will make a buble and mess it up... so after u heat it up a little take good seasors and cut than heat up uncut parts and cut and so on till u finish cutting.. also i used heat gun to take the tail light apart instead of waiting half hour in the oven.. but with heat gun it's harder to do cause i messed up the light a little... one of them
James92SE
142
Jan 2, 2024 09:23 AM
Apr 16, 2020 05:15 AM
Fbana41
Aug 29, 2016 12:18 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
carid
Sep 17, 2015 05:00 AM
