Parking Lights: How do I change them?
Old Feb 22, 2004 | 01:42 PM
MaximaAriq's Avatar
Corner Lights: How do I change them?
I was trying to change my white corner lights to blue, but i can't figure out how to take the old ones out. they look like they're really awkwardly placed. i tried pulling the whole corner light assembly out, but i can't even do that. any help?
Old Feb 22, 2004 | 02:07 PM
maximumspeed's Avatar
Check your owner's manual to show you the diagram on how to replace a bulb in the coner lights, there is a screw you have to take out that's inside the engine compartment,then you use a screw driver with a piece of cloth over it to prie the coner assembly off, the blub sits inside the lens vertically.
Old Feb 22, 2004 | 09:40 PM
MaximaAriq's Avatar
i tried pulling the plastic assembly out by unscrewing the screw that's in the engine compartment, and i tried prying it out using a screwdriver and cloth but it won't budge. i don't have the owner's manual so i dont know how to do it. is there another screw or something i need to take out?
Old Feb 23, 2004 | 10:52 AM
bluestealz's Avatar
Jacked Up off MountainDew
its hard to take out the corner completely...if u wanna just change the light i suggest u stick your hand into that small space thru the engine and turn counterclockwise if u manage to get a grip...then pull it down and out and change your bulb.....
you have to pull the corner out very hard if u want it to come out...to the rear side there is a metal plug that is bigger than the hole it is in ...thats y its stuck in there. if your not careful you will break the light...i've seen it happen. good luck, u do have to yank it out..
Old Feb 23, 2004 | 04:09 PM
MaximaAriq's Avatar
ok i'll give that a try..thanks for the help
spazma7ik
Jan 12, 2017 09:38 PM
Sir Tilus
Mar 22, 2016 01:49 PM
05RLS2
Sep 27, 2015 09:24 PM
97_GXE
20
Sep 17, 2015 08:12 PM
lrb6805
Sep 17, 2015 04:49 PM
