Problem changing Rear Brake!
Old Feb 22, 2004 | 06:55 PM
Pepide's Avatar
HI!
I have some problem changing my rear brake, It must be the same way that changing the Front!? (changed the front already and didnt have any problem!)
When I tried to push back the rear caliper piston it didnt go back enought to put the new set of pad brake!!! (must put back my old set of pad (crap!)
Do you think that my piston may be cocked sideways or partly seized, or anything else??
Thanck all!
___________________________
Pepide... Run fast bu Run Safe!
Old Feb 22, 2004 | 07:08 PM
wariow's Avatar
look at your title underneath your name
Old Feb 22, 2004 | 07:25 PM
ManualMaxima's Avatar
5th Gen till she dies!
i know on mine it confused me...i had to turn it with a needlenose it was a *****
Old Feb 22, 2004 | 07:38 PM
97maxrob's Avatar
the rubber boot around the piston may be turning with the piston as you are trying to turn it in causing it to bind. If the boot is stuck from trying to turn the piston in you will have to get the piston out by depressing the brake pedal, but careful not to get the piston too far out, using your old brake pad and putting it back together and using your brakes might be the best way to avoid it coming too far out. Lube between the boot and the piston to make sure it doesn't stick and then try again.
Old Feb 24, 2004 | 09:31 AM
Pepide's Avatar
Tank's I didnt know that I have to turn the piston, because the galiper of my my last maxima (1991) was not like this, I had only to push it in!
I got the "spécial tools" form Canadien Tire (12$ Can) and did the job!
Merci!
P.S. Sorry for my "bad" english... I'm better in French!
Pepide, Right tool's Help!!!
Old Feb 24, 2004 | 09:35 AM
Pepide's Avatar
I did it! I try to do a seach, but the system refuse me they acces! I past all the title of the FAQ before posting my question!!
Pepide...
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
egali045
Aug 16, 2015 01:19 PM
RealityCheck
Aug 5, 2015 06:18 AM
