vibration during acceleration...help
Old Feb 23, 2004 | 11:45 AM
tke148's Avatar
I have a 99 SE 5sp with over 100k. I still have the original clutch.
The car drives great and I'm not getting any slipping from the OEM clutch. I do plan to replace it in about 2 months just for preventative measures.
Problem and Questions:
When I drive the car and push on the accelerator up a hill (and sometimes on level ground) I feel a vibration in the pedal and sometimes in the car itself.
Usually this happened when I'm in 3rd, 4th or 5th gear with the RPMs at about 2-2.5k. I've used Red Line MT-90 in the trans since about 15k and changed it once already about 60k. I plan on changing that soon too.
I'm wondering if this "vibration" under load is from my clutch or the trans or something else I'm not familiar with.
Can anyone help out? Anyone else have this with their car?
I'm planning also to replace the bushings in the front with Energy Suspension.
All help would be appreciated.
Thanks.
Old Feb 23, 2004 | 02:07 PM
skiboarder72's Avatar
have you cleaned your throttle body lately? spark plugs?
Old Feb 24, 2004 | 03:27 AM
tke148's Avatar
Yeah, I replaced the spark plugs just about 2 weeks ago. the problem ws felt before and after replacement. Also, the throttle body was cleaned recently.
Old Feb 24, 2004 | 01:47 PM
tke148's Avatar
bump...any one experience this on their car?
Old Feb 24, 2004 | 01:51 PM
you got me
theres lots of smart people on here though
Old Feb 24, 2004 | 06:06 PM
Jatan's Avatar
Make sure there is no air leak and you're running premium fuel (91+). Could be a coil pack problem (99s have this). Go to the Regional section of the forum and see if someone local to you will let you swap coil packs for a minute to see if that's the problem or not I don't know about clutches so not sure about that
http://forums.maxima.org/showthread.php?t=286287
Old Feb 24, 2004 | 06:12 PM
njmaxseltd's Avatar
Sounds like a cylinder thats weak. You could have a clogged or faulty fuel injector or a failing coil pack. A compression test might be a good place to start so you can be sure it's not mechanical - valves, rings ect.
user 11122324
42
Jul 18, 2022 03:35 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
06maxima55
Sep 28, 2015 04:29 PM
alahjahwan09
18
Sep 21, 2015 09:12 PM
Bonka
Sep 14, 2015 11:18 PM
