EVap Purge/flow Code
Old Mar 12, 2001 | 06:52 PM
Wholesale dealer
Hi,
I am getting the 0111 code. It is the evap purge/ flow code.
Does anyone know where the fuel evap switch is??
Any help would be appreciated?
Thanks,
Scott
BTW, I have a 97 GXE Cloth for sale 7900.
Old Mar 12, 2001 | 07:02 PM
Daniel B. Martin's Avatar
The factory service manual says that DTC 0111 is detected when
- EVAP control system does not operate properly.
- EVAP control system has a leak in the line between intake manifold and EVAP control system pressure sensor.
The manual gives a laundry list of possible causes.
- EVAP canister purge volume control solenoid valve stuck closed.
- EVAP control system pressure sensor and its circuit.
- Loose, disconnected, or improper connection of rubber tube.
- Blocked rubber tube.
- Blocked or bent rubber tube to MAP/BARO switch solenoid valve.
- Cracked EVAP canister.
- EVAP canister purge volume control solenoid valve.
- Closed Throttle Position Switch.
- Improper connection of one-way valve.
- Blocked purge port.
- EVAP canister vent control valve.
I don't know of any part with that name.
maxinout93
Oct 31, 2015 02:04 AM
tseng1023
Oct 15, 2015 08:30 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
