Question about intake install
Old Feb 24, 2004 | 01:10 PM
97BLUEMAX's Avatar
i just got done installing my bomz cai and was wondering what goes in the small hole that is between the two small pipes that you hook the hoses up to
thanks
Old Feb 24, 2004 | 01:17 PM
RA030726's Avatar
I'm nutty for Nissans
If its a rubber lined hole, its for the air temp sensor.
Old Feb 24, 2004 | 01:36 PM
97BLUEMAX's Avatar
yea
yea it is the rubber lined hole where can i find the air-temp gauge
Old Feb 24, 2004 | 02:40 PM
maxima98vspec's Avatar
u mean the sensor......i installed my cai like 7 moths ago and i just bearly found that sensor just chillin on top of my tranny....i can't believe that i didn't see it all these times i was working on my car...
Old Feb 24, 2004 | 05:22 PM
97BLUEMAX's Avatar
air temp
does anyone have a pic i have searched my engine bay and can not find it also could that be why my service engine soon light is on
thanks
Old Feb 24, 2004 | 06:13 PM
ManualMaxima's Avatar
5th Gen till she dies!
yes that is why it on.......do you have you stock downpipe in? the pipe that goes next to the radiator. it is on the bottom side of that close to where the stock air box was.
Old Feb 25, 2004 | 04:08 AM
RA030726's Avatar
I bet you unplugged the sensor and left it in the stock intake. You 97 should have the sensor in the "Ram Air" scoop of the stock intake. Its in the bend just before the air box, just remove it, plug it in, and push it into the hole. Then reset you ECU if need be.
Old Feb 25, 2004 | 05:21 AM
ya i did that, but before when the car ran with out that sensor there as no CEL....i wounder y, cause the sensor was just sitin on top of my tranny.
Old Feb 25, 2004 | 06:39 AM
97BLUEMAX's Avatar
thanks
thanks i found it in the stock air ram
Old Feb 25, 2004 | 06:43 AM
C MAX's Avatar
it should be right near the shock wall, just trace the wire from the maf sensor should be around there
95Maxi
Aug 29, 2015 09:38 PM
98nismomax
Aug 26, 2015 03:03 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Maxboy23
Aug 11, 2015 11:59 AM
