Fudgin Wheel Hop!! Mad!!
Old Feb 24, 2004 | 10:04 PM
nismos14's Avatar
§è~® f®ÈÄk
grrr i can't stand it. what can i do besides motor mounts to get rid of my wheel hop? i have a 5 spd, and i had the mounts replaced. helped a little but in the wet weather it still hops like a mother!!! is there nothing else to do?
Old Feb 24, 2004 | 10:09 PM
matty's Avatar
1) tires
2) Polyurethane bushings up front
-matt
Old Feb 24, 2004 | 10:39 PM
nismos14's Avatar
§è~® f®ÈÄk
could tire pressure affect wheel hop?
Old Feb 25, 2004 | 12:25 AM
michaelnyden's Avatar
you need to fill your engine mounts with polyurethane or something else.....alternatively, you could the place racing mounts, but they make you car idle really rough i hear and considering you just replaced your current mounts, you shouldn't get new ones again, just fill 'em...
Old Mar 1, 2004 | 06:45 PM
95maxrider's Avatar
Lightly modded
By having the mounts replaced, do you mean with OEM ones, or the PR mounts? If you still get wheel hop with the PR mounts, I would think something is wrong. If you replaced them with stock mounts...then get the PR mounts if it bothers you that much.
Old Mar 1, 2004 | 07:05 PM
nismos14's Avatar
§è~® f®ÈÄk
oem mounts, i dont have the money for PR mounts yet bah!
Old Mar 1, 2004 | 07:18 PM
optimus310's Avatar
stiffer shocks can make a lot of difference. At the track when I have my kybs adjust at 1 on the front, I get some mean wheel hop almost thought the whole first gear. Then I set them at 4 and there is no wheel hop
Old Mar 1, 2004 | 07:20 PM
nismos14's Avatar
§è~® f®ÈÄk
ahh maybe my tok blues are chitty
Old Mar 1, 2004 | 07:45 PM
Dave B's Avatar
Not DAVEB the parts guy
If you only get most of your wheel hop on slick surfaces, then just be a little more careful. Remember that quick acceleration on a wet surface is nearly impossible regardless of what you drive. Wheelhop on a wet surface just isn't a Maxima thing. My 94 Z28 did, my 90 CRX Si did it (horribly), my 86 Honda Accord, my fathers old 96 Tahoe, and even his 04 Sienna.
Dave
Old Mar 1, 2004 | 08:29 PM
BEJAY1's Avatar
Conecarver
What about those lower braces too that somebody was offering?
Oh, and if you still have your old engine mounts and they're in good condition let me know. I just picked up my 80shore urethane today and will have extra after I fill mine.
Old Mar 1, 2004 | 08:51 PM
nismos14's Avatar
§è~® f®ÈÄk
yea it is more in the rain i guess i'll just chill out in the rain
Old Mar 1, 2004 | 09:33 PM
Nismo's Avatar
what about on dry asphalt? I have somewhat sticky tires (yoko es100) and I tried to launch and ended up burning out a bit but the car started jumping and shaking up the dash and I can hear some banging so is that normal? It got the tires smoking a little tho. Stock tires I can spin them to redline and not shake the car at all.
Old Mar 1, 2004 | 09:51 PM
matty's Avatar
Warpspeed were suppose to come out with those front braces...I havent heard anything about them
-matt
Old Mar 1, 2004 | 09:52 PM
nismos14's Avatar
§è~® f®ÈÄk
thats not good, it is normal tho, my car used to do it, it did it more with the old mounts, with the mounts replaced it doesnt do it anymore. the banging and breaking is wheel hop and its terrible on the trans and the car itself.
Old Mar 2, 2004 | 10:56 AM
wasn't there something about putting erasors in your engine mounts a while back (you know the pink ones you used to use in elementary school) i tried it, but can't fit any in the mounts...they just won't go, either the mod is BS or im trying to put them in wrong....they say you can do it without taking your mounts off if you oil up the erasors first...has anyone else tried this? did it work?
Old Mar 2, 2004 | 11:42 AM
samiam's Avatar
E36 ETR
try to launch with slipping the clutch some .... that fixed it for me and lowered my E.T.s
Old Mar 2, 2004 | 02:26 PM
nismos14's Avatar
§è~® f®ÈÄk
i do slip the clutch but when i dont do that i get hop on wet surfaces, if i do, i still get hop on wet surfaces, not on dry. as far as erasers in the mounts, that won't work cuz they wear out so quickly
Old Mar 2, 2004 | 03:38 PM
Jatan's Avatar
I get wheel hop too. I don't get it on dry surfaces anymore after I replaced the tires, but I do still have it sometimes in the rain, but I try not to go WOT when the weather is bad I think lower tire pressure will give you more "contact" with the ground, but worse gas mileage. I get better gas mileage at 35psi than at 29psi (factory setting).
Old Mar 2, 2004 | 05:15 PM
RI-Max's Avatar
ok i have PR mounts and ES control arm bushing endlinks/frame mounts and the mounts helped out alot but i still get hop 2.
trust me i drive hard. casue i checked my mounts and they where cracked!!!! called up PR and told me 2 ship them 2 them. life time warrty. they said they neva seen anything like it.. lol
Old Mar 3, 2004 | 04:13 AM
samiam's Avatar
E36 ETR
Wheel hop is something that is just inherent to FWD... you can never stop it, you can just decreaseit.
Thats why I am building a RWD beater... Befor my max, I had a modded 300zx... RWD no wheel hop there...
Old Mar 3, 2004 | 04:54 AM
eng92's Avatar
Actually on a slick surface, you can get wheel hop in a rwd with independent rear suspension. I used to get it all the time in an older Toyota Supra I used to have.
Under identical conditions wheel hop is much more prevalent in a fwd. It is merely a function of traction and spring rates. Because of the weight transfer to the rear, when launching, our available traction is reduced whereas for a rwd it is increased.
Old Mar 3, 2004 | 07:44 AM
has anyone done the erasor trick on their mounts? did it work? how did you fit the erasors and how many did you need? was it hard? the search function as you all know doesn't work, so I can't view the thread of the past regarding the subject....where can I buy poly urethane and how much would I need if I wanted to filll my mounts? is there anyway to do this while the mounts are still on the car?
Old Mar 3, 2004 | 08:16 AM
Teameyekon's Avatar
It might not be your mounts at all...I thought that I had a motor mount problem, but it turned out to be a leaky front strut. It caused my wheel to jump like crazy. Changed my strut and it was all good after that.
Old Mar 3, 2004 | 11:07 AM
wouldn't a leaking strut make your suspension bounce with aftermarket lowering springs though, so you would know if you had a leaking/blown strut, because it wouldn't be able to properly dampen your high spring rate such as my eibachs, so I know it's not those, cause my handling would be crap if I had a leaky strut...
Old Mar 3, 2004 | 11:28 AM
dave harms's Avatar
rear wheel hop
I had a BMW 325 that could hop crazy bad.
I believe it has a lot to do with everything mentioned, but one more thing..
The 1st gear ratio, my beamer would only go up to 40kph tops in 1st. Thus when dumping the clutch at 4k the tires are not spinning wildly, just a bit more than the speed of the vehicle.
If our Maximas (stick) ran to 70kph in 1st, then the tires would spin faster at first acceleration (and a given rpm), and be less likely to hop. The hop is amplified by a 'tractor like' first gear. Our cars are not bad, many are worse (like my beamer!!)....
So, to a degree we are stuck with it. It's just a matter of finding out if it's more than normal. (and any rain 'tromp' is going to produce a funky loss of traction, giving a variety of feed back)
I enjoy 'giving it' in a controlled manner(only as much as the wheels can take with out breaking loose). Rather that spinning in 1st, take of as fast as you can without breaking loose! It takes people by supprise, quieter, etc. It can even teach better controll of the vehicle in extream environments... you get a better feel for 'cut out'.
On the 'edge' the gas is not an 'on' / 'off' button, it's millimeters.. 'cause that's all you can do and stay on the road!!
dave h.
Mar 12, 2020 12:06 AM
Fbana41
Aug 29, 2016 12:18 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
Andy29
Sep 29, 2015 05:32 AM
