Swirl solenoids keep going bad after engine swap
Old Feb 25, 2004 | 06:15 AM
jillumjill's Avatar
Hi there, got a 99 junkyard engine installed in 99 max. CEL came up - diagnosed to bad swirl solenoid, replaced with new. CEL reset. After driving for 3-4 times, CEL comes back again with same problem. Why would this solenoid keep going bad? Anything to do with engine swap?
Last mechanic to see the car complained that the previous mechanic had damaged the screw on ECM that is used to check the CEL. Could that have anything to do with this - say if the screw is not fully turned back counterclockwise?
Old Feb 25, 2004 | 09:32 AM
jillumjill's Avatar
any tips??????
Old Feb 25, 2004 | 10:26 AM
vipervadim's Avatar
I like Maximas
swirl valves are only on 99 cali maximas i think you might have a new 99 california spec engine instead of the fed spec that you had.
Old Feb 26, 2004 | 06:29 PM
jillumjill's Avatar
So should I disconnect the wire running from the swirl valve to ECM? Which one is it?...............
CorollaULEV
30
Aug 9, 2021 08:11 PM
FlaMark
25
Aug 28, 2015 10:15 AM
doobadoo
Aug 15, 2015 06:43 PM
