how do i fix the lights behind the heater picture buttons (vents, feet, defrost, etc)
Old Feb 25, 2004 | 05:51 PM
95maxcntrljrsy's Avatar
the lights dont work behind the buttons- any ideas?
Old Feb 25, 2004 | 05:52 PM
wariow's Avatar
maybe you blew a fuse. Check the bottom left fuse box inside your car right below the steering wheel column
Old Feb 25, 2004 | 06:01 PM
no - checked already
Old Feb 25, 2004 | 06:22 PM
ManualMaxima's Avatar
5th Gen till she dies!
check your dimmer and make sure it is on. maybe you buned out the lights or somehting like i did!!!!
Old Feb 25, 2004 | 06:29 PM
loco max's Avatar
i just took mine apart a few weeks ago it has a blub, you may whant to check
with the dealer to see if thay have one before you take it apart, none of them near my house had it and autoparts stores dont carry them it took almost a week to get it from dealer, cost about 4.00 its a bit of a pain in the a$$ to take apart so you may whant to get blub before you take it apart. i had to leave the unit out of the car rather than puting it back together and having to take it out again when the blub came in
Old Feb 25, 2004 | 06:35 PM
just one bulb for all 4 or 5 buttons (forget how many are there)
Old Feb 25, 2004 | 06:40 PM
loco max's Avatar
yes, it has one blub for all the top buttons , one for the blue/red temp indicator and a/c button, and one for the fan speed dial 3 total you have the manuel a/c right?
Old Feb 25, 2004 | 06:47 PM
JetBlack SE's Avatar
Does anybody know the exact type of bulb since I know mine blew out cuz all im getting is the temp indicator and the fan speed lite up. the others dont. Thanks in advance
Old Feb 25, 2004 | 06:53 PM
yeah i have manual
Old Feb 25, 2004 | 06:54 PM
yes id also like to know - thanks
Old Feb 25, 2004 | 07:07 PM
loco max's Avatar
this is for manual, the part # for the top buttons and the temp Blue/red is
27545-40u00 i did not need the one for the fan switch, so i dont know what the part # is. its different because it a little bit longer, but just to see if one of the others worked in its place i switched them and it works fine. i could not tell the differnce (i did this when it was dark)
Old Feb 25, 2004 | 09:11 PM
Ceasars Chariot's Avatar
Old Maxima Legend
maybe a wire is loose somewhere in there. i didnt even know my lights were out and i took my headunit out to sell it, anyways i touched a wire or something on accident trying to even out the front dash parts around the ac part anyways, and all the lights flashed on, i thought what tha ?
anyways reached up in there a few more times to see if i could find out which wire but nothing happened and havent thought about it since until i came by this post.
vingodine
45
May 21, 2016 12:46 PM
homeyclaus
Sep 3, 2015 06:15 PM
TMartinLVNV
Aug 16, 2015 01:48 PM
doobadoo
Aug 15, 2015 06:43 PM
acw
Aug 7, 2015 04:20 PM
