besides MEVI- what performance mod is left to do???
Old Feb 26, 2004 | 12:08 PM
Spaniard's Avatar
OK folks- I am getting a lightweight flywheel and aftermarket clutch kit..
Right now I am only concerned about performance mods and want to stay N/A - (I just got the JWT ECU and dont want to have to deal with changing it anytime soon)
What else can I do to gain power/handling? (besides MEVI)
I have done the following:
JWT ECU
Stillen B-Pipe
Stillen Y-pipe
Stillen Muffler
Stillen Front Strut Tower Brace
Stillen Rear Sway Bar
Eibach Pro-Kit Springs
Slotted/Cross Drilled rotors
Light rims (12 lbs)
Unorthodox Racing Underdrive Pulley
Warpspeed Metallic Substrate Hi-Flow Cat
Custom RAM-Air-CAI
K+N Air Filter
NGK Copper (cold spark) plugs
Fluids:
Castrol Syntec Full Synthetic 5-50
X1R oil additive
Redline Lightweight Gear Oil
Royal Purple Coolant additive
Old Feb 26, 2004 | 12:11 PM
RyCrisp's Avatar
Where did you get 12 lb rims from? What size are they?
Only thing I can think of is bigger throttle body? Injectors? Fuel pump?
Old Feb 26, 2004 | 12:14 PM
NiNe7-Gxe's Avatar
some lightweight reduction mods? seats, hoods, etc?
if you want to spend the money i guess you can buy some cams but i hear there is a loss on low end. (im getting on error on searching so i cant check the facts)
Old Feb 26, 2004 | 12:17 PM
happyricefob's Avatar
V^___^V
JWT cams, apexi s-afc, stone racing/cattman header (u will need to swap out ur stillen y-pipe with their y-pipe). pathfinder throttle body. hyper ground system, short shifters...
can't think anymore...
mrnock's Avatar
i dont know if you would consider this a "performance mod" but brake lines sure do make a difference.
maybe fuel system additives/injector service if you're not doing an upgrade on them
Old Feb 26, 2004 | 12:18 PM
V^___^V
why? please explain
Old Feb 26, 2004 | 12:26 PM
Spaniard's Avatar
Whats an s-afc?
How much gain for headers? I heard that they are minimal...
And most importantly- cause I am interested:
Pathfinder Throttle Body:
1) How much gain
2) How expensive
3) Compatible with JWT ECU?
4) Would it give further gains with new fuel injectors and if so what would you guess they are?
Thanks!!!
Old Feb 26, 2004 | 12:31 PM
V^___^V
Originally Posted by Spaniard
Whats an s-afc?
1) How much gain
2) How expensive
Thanks!!!
apexi super air/fuel controller >> http://www.apexi-usa.com/electronics_safc.asp
the gains on N/A are not too much, probably 3-4WHP if properly tuned.
stone racing header + y-pipe on mr. eous's 1999 SE-L:
before:
174.6whp - 189.2wtq
PopCharger
Midpipe
Testpipe
Stock 16 SE-L rims
after:
189.13whp - 198.58 wtq
stone racing header
stone racing y-pipe
PopCharger
Midpipe
Testpipe
Stock 16 SE-L rims
i'm not personally too experienced with pathfinder throttle parts.... but i know it's definetly cheaper than JWT ECU.
Old Feb 26, 2004 | 12:35 PM
Spaniard's Avatar
From machiii.net
They are small 15x6.5 rims- dont look as nice at 16 or 17s... but they spin up quick!
they are rota slipstreams for $450 a set shipping included
The guy gave me a killer deal since I picked em up and 1 had a scratch on it. Like the set was $375!! So I feel the need to pass some business his way whenever I can.
check out
www.machiii.net
Tell me more about injectors and what I can expect? I thought the air was somewhat of the limiting agent not fuel so would I need a new throttlebody (ala pathfinder) to maximize that route?
Tnx
Old Feb 26, 2004 | 12:41 PM
V^___^V
Tnx
to my knowledge (i may be wrong, if so correct me), since pathfinder 90mm throttle body is bigger than stock maxima throttle body, therefore allowing more air-flow from the intake path. basically when you go WOT, more air can be inducted to the engine with pathfinder 90mm throttle body over stock, therefore more WHP.
Old Feb 26, 2004 | 12:46 PM
Ceasars Chariot's Avatar
Old Maxima Legend
hks twin power ignition - most people say wont do much for us
cattman headers - with more mods , maybe more results ? you have lots of mods so with mevi maybe a bit more can be squeezed out of them over y pipe alone.
fidanza flywheel - maybe something here but im not to clear on the flywheel thing. something to have laying around in case clutch goes out
cf hood - they say 20 lbs lighter or more
odyessy lightweight racing battery - between hood and battery that 35 pounds off the front, might help you turn better and nice weight reduction.
racing seats if you dont have them - another BIG weight savings if you have leather seats
hey spaniard did you dyno at that meet, pm me over some results ...
honestly i dont know what we can do at this point - turbo, or nitrous
Old Feb 26, 2004 | 12:47 PM
Spaniard's Avatar
before:
174.6whp - 189.2wtq
PopCharger
Midpipe
Testpipe
Stock 16 SE-L rims
after:
stone racing header
stone racing y-pipe
PopCharger
Midpipe
Testpipe
Stock 16 SE-L rims
Wouldnt most of those gains be the Y-pipe and not necessarily the headers???
Old Feb 26, 2004 | 12:52 PM
V^___^V
hehe he's got that already.
possibly...
Old Feb 26, 2004 | 01:04 PM
Spaniard's Avatar
Thanks for the responses. Im interested in the Pathfinder Throttle body so I am gonna start a new thread with my questions...
(check out the new signature!!)
Old Feb 26, 2004 | 01:10 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
If you have the Money you sould get this...
http://www.stillen.com/Sportscars_de...id=3156&page=1
Old Feb 26, 2004 | 01:12 PM
nismos14's Avatar
§è~® f®ÈÄk
wooooooo that sig pic is sick! i think ur best bet is to do some weight reduction. the headers will yield you somewhere like 4-5 whp more with the mods u already have. the pathfinder tb is best for FI in my opinion. you would also need a custom spacer made for it, so keep that in mind. good luck
Old Feb 26, 2004 | 01:15 PM
JeffesonM's Avatar
living out of a maxima...
Just out of curiousity, if you've got the JWT ECU, why not get the MEVI? I think it's only $100 for them to reprogram it, so with a 7,000 RPM redline and a MEVI you'd be in nice shape. Maybe throw in some cams while you're at it...
Old Feb 26, 2004 | 01:20 PM
Spaniard's Avatar
Thanks!
On 2nd thought I probably am just gonna have to stop modding after the MEVI.
Its getting ridiculous!
Oh, but I really need better brakes... Great.. Another $1500 plus 16 inch rims to fit the fastbrakes and since they have to be SSR type C thats another $1000. This modding thing I swear is going to take all my scrilla.
Old Feb 26, 2004 | 01:25 PM
CystumMax's Avatar
They don't Make those JWT ECU upgrades for 99 Maxima's right?
Old Feb 26, 2004 | 01:30 PM
ilumo's Avatar
I dont know if these have been mentioned... but for performance:
-Subframe connectors
-Energy Sus Bushings
-Better struts/coilovers
-Stickier tires
try those out
Old Feb 26, 2004 | 01:33 PM
SonicDust187's Avatar
Why are you using colder plugs?
Old Feb 26, 2004 | 01:34 PM
A-Ron Max's Avatar
Nope, it doesn't look like they ever will either despite the demand for one
Old Feb 26, 2004 | 01:37 PM
CystumMax's Avatar
Why don't they make it, is it because its harder to make one for 99 Maxima. If the Engine is the same from 95-99, why it woudn't work in the 99 maxima?
Old Feb 26, 2004 | 01:39 PM
nadir_s's Avatar
vicodin ... gift of life
JWT ECU
Stillen B-Pipe
Stillen Y-pipe
Stillen Muffler
Light rims (12 lbs)
Custom RAM-Air-CAI
K+N Air Filter
Fluids:
X1R oil additive
you're crazy.
and so is your ram-air CAI!
Old Feb 26, 2004 | 01:50 PM
Tatanko's Avatar
Bacon Lover
The engine is the same, but the ECU is not. Correct me if I'm wrong, but I'm pretty sure there's like 3 or 4 MINORLY different versions of the ECU (95/96, 97, 98, and 99)
I forget how 97 is different, but it was changed; 98 it was changed because of the digital odometer, and 99 is different also.
ALSO: The Pathfinder TB is 70mm, not 90mm.
Old Feb 26, 2004 | 01:58 PM
WillMax95's Avatar
Bolt On Turbos!!!!!
Old Feb 26, 2004 | 02:09 PM
speedemn's Avatar
Poly-urethane motor mounts would help with power transfer. You wouldn't make more power per-say, but you'd put more power down.
I think everything else has been mentioned.
Old Feb 26, 2004 | 02:19 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
i just caught this thread but i am wondering the same thing. if you are running na all the time, you could pick up some power by sticking with the stock heat range.
Old Feb 26, 2004 | 02:25 PM
Spaniard's Avatar
Well, thats a good point..
I figured it would keep the knock sensor from ever getting into the equation
Also, they are cheaper by like a factor of 9...
You think platinum plugs would bring a few HP to the party? Maybe thats what kept me out of the 200 torque club.
Old Feb 26, 2004 | 02:31 PM
sloppymax's Avatar
i am not suggesting platniums, just sticking with the stock heat range of 5. for coppers, you will just need BKR5E-11.
Old Feb 26, 2004 | 02:35 PM
Spaniard's Avatar
Oh- whoops... I just looked at the invoice and thats what I have (the 11's)
I guess I am not running with a colder spark... somehow I thought that coppers did that "automatically"...
Another goof!
thanks for helping clarify..
Old Feb 26, 2004 | 02:38 PM
sloppymax's Avatar
Another goof!
the 11 is just the gap. check out this page for clarification. the stock heat range is 5. if you are running anything above that then that is colder. lower than 5 is a hotter plug.
Old Feb 26, 2004 | 02:41 PM
maxima98vspec's Avatar
does anyone know what the web addy for the weight redction #'s for the max????? please pm me..
mitch33x's Avatar
BBK owns on the track
Old Feb 26, 2004 | 02:46 PM
sagamax's Avatar
Give me a Bud Light Holmes
i know right im still waitin for an ecu upgrade for my 98
Old Feb 26, 2004 | 02:48 PM
sagamax's Avatar
wow spaniard your brakes look uncomfortable under those 15s. do you have problems with those rims and the size of those brakes.
Old Feb 26, 2004 | 10:27 PM
Nealoc187's Avatar
SLOW
Bigger wheels to fit bigger brakes under.
Subframe connectors.
Flywheel.
Stickers :P
Old Feb 26, 2004 | 10:58 PM
Nismo's Avatar
Lsd .
Old Feb 27, 2004 | 03:29 AM
Tatanko's Avatar
Bacon Lover
You'd be better informed if you read my reply earlier in this thread...
Old Feb 27, 2004 | 12:39 PM
sagamax's Avatar
so are you sure that any upgraded ecu will work with my car. will i just have to check for 5 speed and that it matches up with my car as a gxe
